Headlight warning light on dash
Freerider
Post by Freerider » Mon Jan 13, 2020 1:28 pm
Hi..I've got a caddy 16 plate and the headlight warning light goes on and off ,but is on mostly now ,the headlight is fine so was thinking it the sensor that is at fault ,does any one know the location so I can test
peely
Re: Headlight warning light on dash
Post by peely » Mon Jan 13, 2020 1:33 pm
Is it definitely headlight bulb out or just bulb out warning light on dash mate 👍
Freerider
Post by Freerider » Mon Jan 13, 2020 1:45 pm
Just the warning light
peely
Post by peely » Mon Jan 13, 2020 1:49 pm
Ah ok , check at the back mate even number plate lights they usually give trouble if warning is on and off , give them a few little taps with your hand see if they go out or in fact come back on ,👍
Freerider
Post by Freerider » Mon Jan 13, 2020 1:50 pm
Cheers mate
Freerider
Post by Freerider » Mon Jan 13, 2020 3:08 pm
So checked all light and ok . Need location of sensor please
Freerider
Post by Freerider » Mon Jan 13, 2020 3:34 pm
Checked all lights and ok ...need location of sensor ..thanks
robblowen
Post by robblowen » Mon Jan 13, 2020 3:52 pm
I had the same thing, it was one of the reg plate lights mate, eventually the bulb blew, I think they can be dodgy for keeping a good connection to the festoon bulbs. I swapped mine for LED and just bent the contacts inwards slightly. No problems since. I think the system checks for bulb out by measuring resistance on each lighting circuit. So there is no sensor as such, just the bcm or ecu (someone will be able to correct me) that looks for a set value, I don't think it knows if its open or short, it just knows the value isn't right so throws up the dash warning.
Freerider
Post by Freerider » Mon Jan 13, 2020 5:30 pm
Freerider
Post by Freerider » Wed Jan 29, 2020 1:53 pm
Located fault to one of the bulbs on the rear side lights,
Where the solder had a hole in the middle ,giving the intermittent warning light :D
peely
Post by peely » Wed Jan 29, 2020 3:55 pm
Glad you found it mate gonna look at mine now as mine playing up now and it ain’t number plate lights 😳🙈
Freerider
Post by Freerider » Wed Jan 29, 2020 9:22 pm
Good luck dude
