Bonnet sound proofing
Vwjack88
Post by Vwjack88 » Mon Jan 13, 2020 8:38 pm
For my 06 caddy I got the bonnet sound proofing/insulating pad thing, similar to the one in the photo (that's not a caddy one) Was wandering if you can get them for a 13 plate? Took the one off my 06 to see if it fits but different shape as bonnets different.
Thanks In advance Image
Bionicman
Re: Bonnet sound proofing
Post by Bionicman » Mon Jan 13, 2020 9:27 pm
Yes you can get them of a Touran. Part No is 1T0863831G. There are also cheaper aftermarket ones available if you search on ebay.
Vwjack88
Post by Vwjack88 » Mon Jan 13, 2020 9:29 pm
Thanks buddy. Yeah I've seen the stuff that you cut and stick yourself, was after an oem cheers for the part number pal
Bionicman
Post by Bionicman » Mon Jan 13, 2020 10:08 pm
I was not on about the cut and stick yourself insulation as an aftermarket solution, there are manufactures that do the replica under bonnet insulation covers like the VW one.
Vwjack88
Post by Vwjack88 » Mon Jan 13, 2020 10:11 pm
Oh right, brilliant. Any idea where could get one from, I've messaged a few people breaking tourans, but the only stuff I see on ebay is that stuff.
MattV04
Post by MattV04 » Mon Jan 13, 2020 11:02 pm
Hi there, recently bought a MK4 caddy, am looking at getting engine under tray, engine cover and bonnet insulation. Struggling with part numbers and don’t wanna buy then have to send back if wrong. I know this is prob very boring and common but I joined this today so be nice 😜
MattV04
Post by MattV04 » Tue Jan 14, 2020 10:12 pm
Anyone able to help 👆🏻🙏🏻
Bionicman
Post by Bionicman » Tue Jan 14, 2020 10:33 pm
Will have a look tomorrow mate if no one else has got them by then.
MattV04
Post by MattV04 » Thu Jan 16, 2020 10:32 am
Any luck mate?
dan@biali
Post by dan@biali » Thu Jan 16, 2020 11:56 am
Could you not just pop into a VW van centre parts dept and get them to order it based off your reg, that way you know its the right part.
Bionicman
Post by Bionicman » Thu Jan 16, 2020 3:25 pm
Part No for VW Caddy Mk 4 under bonnet insulation - 2KO863831A
Ghost-rider
Post by Ghost-rider » Thu Jan 16, 2020 4:40 pm
dan@biali wrote:Could you not just pop into a VW van centre parts dept and get them to order it based off your reg, that way you know its the right part.
Good luck with this, i get fed up of hearing "unless your van came with it, it harder to find the parts", dont get me wrong my local van centre is generally quite good, but iv found its a lot easier just givin em a part no., if it a part im lookin to retro fit.
MattV04
Post by MattV04 » Thu Jan 16, 2020 9:50 pm
Thanku for the part number, VW seem to only help if u have the correct part number. Be told at work if ordered and wrong I can’t return it so thanks for all ur help
Vwjack88
Post by Vwjack88 » Thu Jan 16, 2020 10:47 pm
Can you remember where you saw these bud? Still cant seem to find any.
Bionicman
Post by Bionicman » Fri Jan 17, 2020 9:46 am
Found one company in uk that sells them - Winparts.co.uk. Its a Van Wezel one, almost identical to the VW oem one but less than half the price at £33.79..
Please note that this is for the Mk 3 Caddy only. The winparts product number to type in there search box is 1017700.
Hope this helps other forum members looking for a cheaper alternative to the VW oem bonnet insulation.
