Locking wheel nut key
- Stevemaxi
Hi, I have just tried to get a replacement locking wheel nut key from vw. My caddy apparently doesn't have oem item fitted anymore and someone has put mcgard brand on.
Is it best to just bin them and replace with vw ones or any recommendations from you guys?
I am currently running with a can of instant repair just on case
- Beaker2135
Re: Locking wheel nut key
I’d bin them, probably cheaper to buy a new set than get a key
VW do a set of accessory locking nuts for about £25 ZGB-1J0-071-591-A
as opposed to £80 for the regular ones as far as I know they are just the same apart from the part number
- Barbel330
Nothing wrong with the McGard brand, they’re well regarded.
Instagram: @y_5cuf
The VW splined ones are childs play to remove, would rather mcguard ones but a pain to match a new key if you lost your
- Stevemaxi
Thanks for the suggestions.
- Ghost-rider
As said already, mcgards imo are far better than the vdub lockin nut
- Stevemaxi
I'll try and contact mcgard to get a replacement and go from there.
Thanks again for the information
- Cabbs
I lost my mcgard locking nut. I rang them and they asked me to send over a clear picture and they matched it. I run a set of vw and mcgard ones now. Lol
- Stevemaxi
Thanks, that sounds promising I will try ringing them and hopefully get sorted.
Hi have you a link for these please as I have the exact same issue.Beaker2135 wrote: ↑Tue Jan 14, 2020 8:43 am I’d bin them, probably cheaper to buy a new set than get a key
- Lister79
Hi, if you take the part number quoted by Beaker2135 into a VW dealer or TPS they will be able to supply them.
