Heated mirror not working
Nbev
Post by Nbev » Wed Jan 22, 2020 10:56 am
Can anyone help?
My drivers side mirror heater has stopped working but the passengers side is still working fine, anyone know if theres any common faults with these that I can check before I take it to the stealers?
My windscreen washers have also stopped spraying out even though ive topped it right up and i can hear the motor for it, any help on this problem too will be much appreciated.
Caddys a 16reg...
Post by the swan fiend » Wed Jan 22, 2020 11:02 am
I’m not sure weather both mirrors are on the same fuse but I’d check that first. As for your washers, sounds like you may have a blockage or kinked pipe somewhere. I’d try looking for that before taking it in
Bionicman
Re: Heated mirror not working
Post by Bionicman » Wed Jan 22, 2020 11:36 am
My passenger side heated mirror stopped working years ago so I took it in to VW and they replaced it for approx £85.00. I think you can get the heated mirror glass relatively cheap and do it yourself. As for your windscreen washer I agree with swan that it is possibly a blockage somewhere in the pipe work before the split between the washer jets. Just had a quick search for the heated mirror glass and Autodoc sell them for less then a tenner if you have the big door mirrors fitted. I am not sure what the new smaller shape ones cost if you have them.
Winst
Post by Winst » Wed Jan 22, 2020 12:13 pm
The mirror glass just pulls off, and there’s 2 connectors on the back for the heating part, check your getting power to it, then you’ll know if it’s a mirror glass issue or not.
2011 2.0tdi Full 2018 front and rear ends fitted, airlift 3P suspension, 20" alloys, modified Porsche calipers front and rear with R8 handbrake caliper, Audi RS4 wingbacks, covered in nappa leather and alcantara, Touran dash, door cards, centre console all trimmed in leather and alcantara, MFSW, 3D cluster, Rockford fosgate and focal sounds with MIB2, bi xenons, full alltrack kit fitted, etc etc:D
Instagram @2kwayne
Nbev
Post by Nbev » Wed Jan 22, 2020 1:36 pm
Cheers fella’s
I’ll have a look on Sunday and see if I can fix those problems!
Much appreciated 👌🏻
Snapsgti
Post by Snapsgti » Sun Feb 09, 2020 9:51 am
Did you find the problem to your mirror not working as I have the same problem with my new van?
SnoWhite
Post by SnoWhite » Sun Feb 09, 2020 11:16 am
It is worthwhile trying to isolate the fault - assuming they have worked previously then the element may simply have burnt out. I have replaced two in 5 years. When I bought the second the dealer warned me to leave the setting to off position except when needed especially during the summer.
If neither heated mirror is working, then the chances are its a common mode failure so inspect the fuse and check you have not moved the switch to the off position whilst adjusting the mirrors.
If its just one faulty mirror then it is well worth DIY rather than asking VW to investigate - so carefully prise out the mirror from its mount. It is just clipped into place so you should be able to carefully insert a wide plastic(or with care metal) blade or spatula behind the mirror to release the mirror from its housing.
Carefully release the two spade connectors which feed power on the back of the mirror and then fire up the engine and use a multi meter to test for 12 volts across those two terminals when the heated mirror switch are set to on. If there is power - then the element inside the mirror is almost certainly broken so buy and fit a replacement.
No voltage means you have an issue downstream and need to check the fuse is OK and then circuit test the cabling to find out why.
Snapsgti
Post by Snapsgti » Sun Feb 09, 2020 11:43 am
That’s great thanks for the info. Will have a look when the wind dies down 😂👍🏻
