Caddy door speakers
Cossieminor150
Caddy door speakers
Post by Cossieminor150 » Thu Jan 23, 2020 7:36 pm
Hi
I’m thinking of changing my door speakers but not sure in what to buy
Any ideas would be great!!!
Beaker2135
Re: Caddy door speakers
Post by Beaker2135 » Thu Jan 23, 2020 8:07 pm
Skipton car radio do plug & play kits with or without tweeters, give them a shout
Post by gazza31112 » Sat Jan 25, 2020 4:41 pm
It's a pain to do tbh, If I knew I wouldn't have bothered! I put two new pioneer 6x9s in my bulkhead so I thought I'd change the door ones aswel, you also need speaker adaptors
I got this set off Amazon.
You have to drill the rivets out of the original speakers then screw/clip the adaptors and speakers in, then remove original connector and wire it into new speakers.
After I wired my bulkhead speakers (above headrests) in I can't even hear the door ones, so kind of seems like a waste of time now! Image
Gas442
Post by Gas442 » Wed Jan 29, 2020 9:37 am
I have put Hertz Mille Pros in my doors and they are the dogs danglies. Depends what you wanna spend..... but you can’t go wrong with any Hertz in my opinion
Ghost-rider
Post by Ghost-rider » Wed Jan 29, 2020 12:08 pm
Gas442 wrote:I have put Hertz Mille Pros in my doors and they are the dogs danglies. Depends what you wanna spend..... but you can’t go wrong with any Hertz in my opinion
Did you amp these, or just a direct swap, like for like mate??
Modelno
Post by Modelno » Sun Feb 16, 2020 4:51 pm
Hi, does it take a lot of work to disassemble the door panels? Thank you
Post by gazza31112 » Sun Feb 16, 2020 5:23 pm
Only a few screws under the door handle and some clips on the bottom, 5 min job
Modelno
Post by Modelno » Sun Feb 16, 2020 6:46 pm
thank you, I will soon change the speakers, greetings
Post by gazza31112 » Sun Feb 16, 2020 6:54 pm
Longer job to replace speakers lol but door cards are easy.
You have to drill out the rivets holding the old speakers in and use adaptors for the new speakers
Pepsi
Post by Pepsi » Sun Feb 16, 2020 9:20 pm
It is bit long time replace then but well worth it in my opinion. Went for some jl audio c1 components.
Also looking at getting some jl audio sub behind a seat. Probably an 8/10 "
Post by Stedlocks » Sun Feb 16, 2020 9:30 pm
I've just put a little Kenwood sub under the passenger seat .....its made the world of difference to the sound in the van. Even with the stock shitty speakers!
Modelno
Post by Modelno » Mon Feb 17, 2020 3:40 pm
Hello, I have prepared brackets and adapters, in addition to isolation, the worst are always the staples, greetings
Gas442
Post by Gas442 » Fri May 15, 2020 11:15 am
@Ghost-rider
Sorry don’t get on here much :D but yes they’re amped with a JL 4 channel as it also runs an under seat JL sub. Thanks
RivalDealer2020
Post by RivalDealer2020 » Fri May 22, 2020 4:14 pm
Hi
I upgraded the speakers in my caddy with a morel maximo woofers and tweeter kit that was previously installed in my clk.
As people have said above the oem speakers are riveted in and have to be drilled out
For me that was the easy part!
The hard part was installing the remote tweeters and wiring. the crossovers that came in the kit I mounted behind the door card and the tweeters to the empty tweeter position in the dash.
To do this I had to create a basic harness, I used single cores from some flexible cable and then use lots of tessa fabric tape to protect them, they where approx 1.5m all in.
Then to route I had to take the rubber door connection loop to bits and feed the cables through that and then up to the dash tweeters.
Over all it’s a big improvement over the standard paper speakers but far from perfect in my opinion.
Its definitely better but as I’m not a audio expert i think my choice of speakers was wrong for a really good outcome.
it’s either super bright with hardly any middle or then way too bassy as I try to adjust it.
I put a small amount of silentcoat mat in the doors and behind my speaker adapters at the same time but not nearly enough, maybe if I used much more in the doors and cab the sound would be much better.
No amp needed as the headunit has more than enough power to drive mine loud, anymore and will just get even more plastic rattles
Also maybe a better VW head unit with higher quality built in amp would give me better results.
Hope your upgrade goes better!
Super64
Post by Super64 » Sat May 23, 2020 6:46 pm
I’ve just got myself a free set of 4 Bose door speakers & tweeters from an A3. Got to be better than standard ones. Running them through a Kenwood DDX5016DAB. Nothing to loose by trying them I reckon. 👍
