Coilover spanner
Mr. T
Coilover spanner
Post by Mr. T » Sun Feb 09, 2020 3:03 pm
Hi, does anyone know what c spanner will fit cobra coilovers. Theres plenty on ebay just not sure which one I need. Pic of the coilovers attached. ThanksImage
Craig Cheatham
Re: Coilover spanner
Post by Craig Cheatham » Sun Feb 09, 2020 6:26 pm
Hi, as long as the C spanner is large and adjustable i think it will be fine, as most of them are adjustable.
Craig Cheatham
Post by Craig Cheatham » Sun Feb 09, 2020 6:31 pm
Hi again, having said what i did in my post above, on closer inspection of your photograph, it looks like you require a specific C spanner with lugs on to locate into the large blue adjuster nuts on your dampers.I hope this helps!
Mr. T
Post by Mr. T » Sun Feb 09, 2020 9:06 pm
Thanks for help, I was thinking the same that I may need a specific one
Kiz
Post by Kiz » Sun Feb 09, 2020 10:06 pm
I’ve just used a decent set of grips in the past I.e knipex ones worked a treat - even on seized ones
Mr. T
Post by Mr. T » Sun Feb 09, 2020 10:40 pm
Okay thanks for the suggestion
