Problem with my caddy dash!
BenC10
Engine size/power: 2.0 CNG (107bhp)
Post by BenC10 » Sun Feb 09, 2020 6:28 pm
Hi,
I'm in need of some help, for the past couple of weeks I have been having problems with the dash lights. When I indicate left on my dash the exhaust gas warning light faintly comes on and off, so does the right arrow indicater. But when I indicate right it works normal!
I hope someone can help!!!
Regards
Ben
Re: Problem with my caddy dash!
Post by Stedlocks » Sun Feb 09, 2020 7:27 pm
Sounds like a bad earth somewhere?
Post by Doc » Sun Feb 09, 2020 7:38 pm
If this is on the old red display instrument cluster fitted on the caddy from 2004-2010 then it is more than likely a failure at circuit board level.
I've seen it a few times where random lights come on with others.
Because the immobiliser is integrated into the instrument cluster it is not a simple swap out.
BenC10
Post by BenC10 » Mon Feb 10, 2020 7:56 am
That doesn't sound good! Where is the Earth for the lights?
BenC10
Post by BenC10 » Fri Feb 14, 2020 9:42 pm
Can anyone help please?
Post by Doc » Fri Feb 14, 2020 10:04 pm
Which generation of caddy/instrument cluster do you have?
BenC10
Post by BenC10 » Sat Feb 15, 2020 9:34 am
2010 caddy maxi
