Armrest from a Caddy maxi
- ÖrjanR
Hi! I have a Caddy 2011 which there is no armrest in. Can i fit a Touran/Caddy maxi tunnelconsole with armrest? I noticed it has ventilation in the back which i do not have in my because of the middle wall. If someone could give me a tip i would appreciate it. Thanks/Örjan in Sweden
Re: Armrest from a Caddy maxi
Yes you can matey just you have to remove the rear panels from it as it won’t fit with it. You just need to trim the bottom of the sides to go over the extended load area flooring overlapping into cabin.
- ÖrjanR
Ok that sounds great! It looked like it was possible in pictures. It seems to be a little bit different mounting holes near the gear boot also but maybe is no problem?
- ÖrjanR
I am now mounting it and i removed the back panel with airguide. Which part do i need to trim in the bottom? Do anyone have a picture? Best regards from Örjanstan-the-man wrote: ↑Fri Feb 28, 2020 7:43 pm Yes you can matey just you have to remove the rear panels from it as it won’t fit with it. You just need to trim the bottom of the sides to go over the extended load area flooring overlapping into cabin.
Hi mate. There’s a guide in the ‘how to’ section. I used that to fit mine
- ÖrjanR
Ok but i am not allowed to come in there yet. I have waited 10 days to be activated to that forum.the swan fiend wrote: ↑Wed Mar 11, 2020 3:10 pm Hi mate. There’s a guide in the ‘how to’ section. I used that to fit mine
Ive just ordered one for my SWB 2018 plate from Direct Car Parts but im not sure if it would fit your model
Fear not mate. Doc will sort it. He’s a very busy man.
