Hampshire Caddy
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Sun Jul 19, 2020 5:09 pm
Looked in there too, doing belt and braces to start with :D
Good pointer though
Black
Marmite lover!!!
VCDS
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Mon Jul 20, 2020 5:26 pm
Updated, updated, updated list
Blanks in wiper scuttle DONE
Dye headlining DONE
paint beige trims DONE
install switch panel DONE
run wires for video etc DONE
blue led headlining lights DONE
headlining light board DONE
Battery box DONE
Air Con fixed DONE
Cruise control DONE
PTC heater DONE
Cruise Control DONE
Sliding window broken catches DONE
Reversing camera DONE for a second time
Trip computer DONE
Engine cover
Shit pipe mod
Detail engine bay
TV (need to find one, all wiring done)
Heated seats
Climatic air con/heating
Footwell lights
Replace cracked brake light
Tinted tail lights (film failed, got spray to try)
Shark fin aerial
Tow bar
Bodywork (scratches on NSR, stone chips, bumper crazed)
Jump boot bed (half built)
Leisure battery
MFSW
Blue needles and LED’s
Wheels
Lowering
Wind deflectors
Aero mirrors if I can’t fix the whistle 100% but is purposefully at the bottom of the list unless find some for 50p
A few coding changes when I can get my hands on VCDS
DRL’s off with handbrake on DONE
Needle sweep (option is disabled, oh well, not fussed)
Indicator flash 3 to 5
Black
Marmite lover!!!
VCDS
C Chis
Hampshire Caddy
Post by C Chis » Mon Jul 20, 2020 5:27 pm
I’m saying nothing
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Wed Jul 22, 2020 3:15 pm
Drl’s Are now off when handbrake is on
Mfd is working
Single button unlock all doors done.
Really must get the error codes off laptop to post on here for help
Black
Marmite lover!!!
VCDS
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Sun Jul 26, 2020 3:01 pm
Just installed my new reversing camera, can’t remove my old one as number plate light holder is broken. Also bulb is blown and one of my new DRL’s has stopped working. Filaments look ok, swapped it from side to side but fault is bulb. Not good as only had 2 weeks and one was faulty when delivered. Recommended off here, if I can find the post I’ll be commenting :evil:
Black
Marmite lover!!!
VCDS
Re: Hampshire Caddy
Post by petrev » Sun Jul 26, 2020 7:48 pm
Hi PB,
I had a numberplate light mounted camera before on a Skoda, but I found it a bit too far off centre !
I have fitted a boot switch camera that looks like an OEM one, but much cheaper.
Works nicely as a camera and I find the boot switch actually seems to have a nicer action than the original one !
This is the one I got
https://www.aliexpress.com/item/32874644229.html
Good luck (lovin your mods)
Pete
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Sun Jul 26, 2020 7:57 pm
Cheers @petrev but I had the number plate one and upgraded to
https://www.ebay.co.uk/itm/Car-Parking- ... 2749.l2649
Recommended on here and is much better
The number plate one is the one I need to remove but my old light holder is broken.
Black
Marmite lover!!!
VCDS
Re: Hampshire Caddy
Post by petrev » Sun Jul 26, 2020 10:25 pm
Yeah the number plate light ones are all wrong !
My one is the Boot handle integrated one now, and I like it.
Where did you mount your new one ?
pomsss
Re: Hampshire Caddy
Post by pomsss » Thu Jul 30, 2020 2:48 am
Hi @Papa Bear,
where are you planning to put the secondary battery? Under the passenger seat?
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Thu Jul 30, 2020 9:55 pm
@pomsss it will be in the boot jump bed with connectors so I can unplug it when removing the bed
Black
Marmite lover!!!
VCDS
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Fri Jul 31, 2020 12:44 pm
Got myself a climatic controller with heated seat buttons, need to go to the scrappy this week to hunt out 2 sensors and wiring.
Hoping to find some sweets soon.
Black
Marmite lover!!!
VCDS
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Sat Aug 01, 2020 11:15 pm
VCDS errors, help needed :(
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation
*since PTC installed
Address 56: Radio
Cannot be reached
*Non OEM radio, has CANBUS box but something wrong.
006012 - Clutch 2
P177C - 001 - Tolerance Limit Reached - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 20
Reset counter: 10
Mileage: 106955 km
Time Indication: 0
Date: 2014.11.28
Time: 15:27:30
Very old date, hoping it has been done, took 3 times to clear, hasn't come back since, should I be worried or is there something I can check to make sure all is well?
Black
Marmite lover!!!
VCDS
Re: Hampshire Caddy
Post by Doc » Sat Aug 01, 2020 11:51 pm
Snapshots from an Autoscan can be confusing, you're best posting everything.
From my reading of what you have posted, your PTC heater is showing as defective so basic settings/adaption is not possible.
This has been discussed on the forum, most times the fault is down to a dry joint.
The CAN gateway showing no communication with the radio is standard when you have a non VW radio fitted. Even with a CAN interface the gateway will recognise it's not a VW radio.
If the clutch fault has gone away, just hope it doesn't come back.
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Sun Aug 02, 2020 9:20 am
Thanks @doc, didn’t want to post the whole lot filling up the forum.its strange that the heater is working but erroring. Will take it out before winter and check it, might remove the fuse for now to reduce risks..
Fingers crossed the clutch was just a one off in 2014 :D
Black
Marmite lover!!!
VCDS
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Thu Aug 06, 2020 3:07 pm
Got the sensors for climatic upgrade and the wires.
Job for another day.
Got some window switches to play around with the leds on too :D
Black
Marmite lover!!!
VCDS
