Hampshire Caddy
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Thu Mar 26, 2020 5:55 pm
Top of the frame is same height as the seats when folded plus 5mm so the plywood will rest straight on it with a layer of foam to protect the seat backs
Caddy Maxi 1.6CDI 102bhp
Black
Marmite lover!!!
mark1a
Re: Hampshire Caddy
Post by mark1a » Thu Mar 26, 2020 8:09 pm
Cheers...
Brescia Clubsport 18” | OE Xenons | Limo tints | Vanstyle side bars | Wind deflectors
Remap 190bhp | H&R / Darkside lowering | TRC front splitter
Android HU | 4G WiFi | Wireless phone charge
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Sun Mar 29, 2020 4:55 pm
Some of the wires I ordered have arrived but not the fuse box connector or the switch panel or the led lights. Thought I’d make a start at running the wires though.
Several wires need to go to the headlining so started removing the b pillar trim on the passenger side. Removed seat belt and grab handle and one push fitting and it pulled off ok. On to the trim above the door.... not so easy! Remove net, take out push fittings and no movement, remove the push fittings in the edge of the headlining, yes they go through the trim, that will be it.... no, the trims either side hide a push fitting underneath so followed the same procedures on them to lift them out far enough for access. Got the trim off at last.
Need to make dinner so returning tomorrow to actually run the wires. Learning all the time.
Black
Marmite lover!!!
Papa Bear
Re: Hampshire Caddy
Post by Papa Bear » Tue Mar 31, 2020 5:14 pm
All wires that I have have now been run and strings run to pull the other wires through when they arrive (hopefully).
Some soldering to do on the wires for the reversing camera then can plug in a cross my fingers.
Leds have apparently been lost by Royal Mail, I think they are just delayed but seller is sending replacements anyway, might end up with 2 lots.
Black
Marmite lover!!!
