Hampshire Caddy
- Papa Bear
Re: Hampshire Caddy
Forgot wheels
And possibly lowering a little as I hate the gap above the wheels
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- C Chis
Re: Hampshire Caddy
My MTB Caddy Build Can be Found Here
- Papa Bear
- Papa Bear
Re: Hampshire Caddy
Learning VCDS
Ran wires for the PTC heater and soldered into the CANBUS, can’t connect it yet as missing the bolt to attach to the fuse.
Fitted the battery box as I had the battery out, jus5 need to ge5 a lid for it now.
Battery reconnected and had lots of dash lights. Bulb, steering, traction.
VCDS arrived half hour later luckily. Ran scan, cleared codes, showing steering angle sensor fault.
Did a Steering Limit Stop Adaptation, all lights gone off
Going out to play with VCDS later to check any faults left, change indicator blink to 5 not 3, enable needle sweep , set DRL’s off when hand brake is on and unlock all doors from one press off unlock on keyfob (not found out how to do the last one yet).
Scrap yard trip tomorrow, and if nothing else, getting another bloomin fuse bolt
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- Papa Bear
Re: Hampshire Caddy
Cruise control installed and coded, air bag took longer to get off than the whole rest of the job!
Indicators now flash 5 times
Still haven’t worked out how to do a needle sweep and the trip buttons on the wiper stalk don’t work yet.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- C Chis
Re: Hampshire Caddy
Awesome!
Double check your SWCM, midline ones will code in for cruise control but not the trip function.
I have a highline SWCM but only a lowline instrument cluster so don’t get MFD
- C Chis
Re: Hampshire Caddy
Needle sweep
Have a look in 17, instruments then under one of the drop down options in adaptation for celebration. Should be in there somewhere
- Papa Bear
Re: Hampshire Caddy
Thank you, will peruse later when trying to get trip computer working. Making dinner at the mo
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
- Papa Bear
Re: Hampshire Caddy
Updated list
Blanks in wiper scuttle DONE
reversing camera DONE (but may change as pointing too low)
Dye headlining DONE
paint beige trims DONE
install switch panel DONE
run wires for video etc DONE
blue led headlining lights DONE
headlining light board DONE
Battery box DONE
Cruise control DONE
PTC heater DONE
Trip computer (needs enabling)
Engine cover
Detail engine bay
TV (need to find one, all wiring done)
Cruise control (bought but not fitted)
Heated seats
Footwell lights
Replace cracked brake light
Tinted tail lights (film failed, got spray to try)
Tow bar
Bodywork (scratches on NSR, stone chips, bumper crazed)
Jump boot bed (half built)
Leisure battery
MFSW
Blue needles and LED’s
Wheels
Lowering
A few coding changes when I can get my hands on VCDS
DRL’s off with handbrake on
Needle sweep
Indicator flash 3 to 5 DONE
Dye headlining DONE
Battery box DONE
Cruise control DONE
PTC heater DONE
Engine cover
Detail engine bay
Heated seats
Footwell lights
Tow bar
Leisure battery
MFSW
Wheels
Lowering
Needle sweep
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Re: Hampshire Caddy
Sounds like you’re getting to grips with VCDS quickly mate.
- Papa Bear
Re: Hampshire Caddy
Wouldn’t go that far
Still a few things to do and then loads more to learn
Fun though
Fun though
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Re: Hampshire Caddy
I can imagine mate. I’d be a bit worried I’d do damage with one. You never know, I may take the plunge one day.
- Papa Bear
Re: Hampshire Caddy
Doing an auto scan every time just in case, making notes of what I change and triple checking here before changing
Sorry if everyone gets fed up with my questions
I’ve got some errors that were there originally that I need to sort, will be requesting help with those.
One is because it’s got a non oem stereo which is fair enough but another is to do with my dsg box which is a worry.
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Re: Hampshire Caddy
Yeah, making a note of any settings you change can get you out of a whole load of trouble!!
Re: Hampshire Caddy
Making notes is not as good as getting used to using the system you've bought and learning how to go to the Ross-tech/VCDS/Debug/CodingLog.CSV for a full run down of every thing you've used it for.
It's invaluable.
There's also an adaptions log in there if you do change any adaptions.
It's invaluable.
