Non runner caddy
chris_wynn
Non runner caddy
Post by chris_wynn » Sun Mar 15, 2020 5:32 pm
Hi, i’ve a 2008 2.0 Sdi caddy which turns over but will not start, the esp light is on and my code reader will not communicate with the ecu. I’ve checked all the fuses and swapped the relays round, can anyone suggest what to look at?
Re: Non runner caddy
Post by Doc » Sun Mar 15, 2020 8:21 pm
Check for power and ground connections at the ECU.
sbyrne2012
Post by sbyrne2012 » Tue Mar 24, 2020 10:44 pm
Possibly a faulty Ecu,seen this before after driving into floods hopefully it’s not though as said before check all connections to and from the ecu first
