Anybody have any idea what this is?
Post by gazza31112 » Sun Mar 15, 2020 8:58 pm
While replacing my light switch today I noticed a little box with four switches tucked in with the rest of the loom.
Doesn't look like it would be standard to me, but I could be wrong.
Anybody got any idea?
Cheers ImageImage
Re: Anybody have any idea what this is?
Post by gazza31112 » Sun Mar 15, 2020 9:00 pm
According to Google it's a dip switch, stil have no idea what it does....
brooneye
Post by brooneye » Sun Mar 15, 2020 9:29 pm
I’ve one for the mfsw to work with an after market hu. Can you not trace it back to find where it goes?
Post by gazza31112 » Sun Mar 15, 2020 10:16 pm
I tried but it goes straight into the loom which goes deeper behind the dash
r1lea
Post by r1lea » Mon Mar 16, 2020 6:21 am
Possibly an aftermarket unit for controlling auto lights / coming home lights etc
Does your van have those features ?
Are they factory ?
Post by gazza31112 » Mon Mar 16, 2020 7:36 am
Na mate, neither of them
Post by Doc » Mon Mar 16, 2020 7:57 am
The sticker says "temperature"?
Those dip switches are probably to change a setting on some system or device.
Is there anything in the way of an aftermarket system in your caddy, something like a night heater or similar?
Failing that, is there any aftermarket system installed? Or maybe has been removed?
Post by gazza31112 » Mon Mar 16, 2020 8:16 am
Yes it says temperature, and not that I know of, I assume it's been used only as a commercial vehicle it's whole life due to where I got it from they had a whole fleet of them with the slamlocks all in the same positions, and very similar reg numbers, so I wouldn't have thought it would have anything aftermarket installed, only if it was some sort of tracker/GPS unit.
Post by gazza31112 » Mon Mar 16, 2020 8:19 am
Ahhh Iv just pulled the light switch trim off and followed it to a blue unit that says GPS on the sticker, so yes I take it it's a tracker ImageImageImage
Post by Doc » Mon Mar 16, 2020 9:01 am
Yep, that looks very much like a tracker.
Post by gazza31112 » Mon Mar 16, 2020 9:17 am
Wonder if I'm still being watched
sbyrne2012
Post by sbyrne2012 » Sun Mar 22, 2020 11:26 pm
Ya it’s definitely a gps tracker I’ve seen these fitted before
