Fixing off Centre rear wheels
michealcaddy
Post by michealcaddy »
So I had a v-Maxx lowering kit installed at the back but the wheels seem to be slightly off Centre, maybe half an inch. To fix this, must I take off the whole kit and reassemble?
Thanks in advance
Re: Fixing off Centre rear wheels
Hi mate, You can buy wheel centralising plates from reflex auto design or similar. I think you can loosen the shackles and insert them.
michealcaddy
@the Swan fiend
Thanks I’ll research them
Giddy
Post by Giddy »
Just make sure you buy the correct ones for your leaf spring. So, before you buy, check whether you have bolt or locating pin in your leaf spring.
Thats assuming your wheels are shifted towards the front, not the lateral shift?
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
michealcaddy
No actually about half an inch lateral
Giddy
Post by Giddy »
Ok, so it was tightened up incorrectly. Loosen up bolts on the both ends of the leaf springs and the hangers, and tighten everything up with the wheels on the ground or ramp. Basically the van weight should be on the wheels when tightening bolts up. In addition to that, polybushing all the rear is highly recommended.
michealcaddy
Ok thanks for help Giddy!
Giddy
Post by Giddy »
No worries, hopefully you'll get it sorted :)
Josh764
Post by Josh764 »
I had this issue when lowering my van and as @Giddy says.. We loosed everything back off and it seemed to correct itself.
michealcaddy
@josh764 yeah hopefully that’ll sort mine too thanks!
