Does the Maxi Facelift have a wider cargo bay?
Tom-8-0
Post by Tom-8-0 » Thu Mar 19, 2020 8:27 pm
Hi all. Just a query I have. I’m in the process of doing the Touran rear seat conversion to my facelift maxi. I Lifted the false floor today but when I went to trial fit the Touran fitting, its like is not even close. Does this need modifying also? I’ve had a look at other builds on here and It seems it should just fit neat where the old floor came out. I ran out of daylight before I could figure it out. It seems like I have to trim the side wings if you like.Image Will get a better shot at it tomorrow hopefully. Just had a thought they might be different. Image
Re: Does the Maxi Facelift have a wider cargo bay?
Post by the swan fiend » Fri Mar 20, 2020 12:01 am
I’m pretty sure the 2k floorpan is all the same from 2003 through to present day mate.
Post by Doc » Fri Mar 20, 2020 7:32 am
Remember you are fitting a Touran rear seat into a Caddy. While they share the same front end, structurally from the A-pillar back they are quite different.
Have a look at photos from others who have done it, the "wings" of seat frame need to be trimmed down somewhat to get them to fit in.
Tom-8-0
Post by Tom-8-0 » Fri Mar 20, 2020 10:36 am
Cheers @Swanfiend that’s the answer I was hoping for. Started to worry a little there.
Thanks @Doc, Yeah it looked like I could make it fit with a little trimming. I Just didn’t want to go cutting into it if others hadn’t needed to. Will have another look at it today.
On another note, never thought just how loud it would be driving once the solid bulkhead was removed. Will definitely have to move sound deadening up the list.
anoneamus
Post by anoneamus » Fri Mar 20, 2020 11:30 am
On another note, never thought just how loud it would be driving once the solid bulkhead was removed. Will definitely have to move sound deadening up the list.Image
I was surprised how loud a "work" Caddy is, even with the bulkhead and ply lining fitted, when I rented one in the UK last year. I have a "premium trim passenger car" Caddy version (Cross) with factory-fitted sound deadening up the wazoo. Quieter than many cars I've been in, even at 120mph on the freeway!
Jamk
Post by Jamk » Fri Mar 20, 2020 12:24 pm
It’s should be fine, mines a SWB and it fitted just fine, the seat pivot (where the front of the seat clicks in) panel needs trimming to get it to fit tho
Katiecaddy
Post by Katiecaddy » Fri Mar 20, 2020 1:59 pm
The pans are also a bit different between models, the tie down points on caddy maxi Kombi, to standard caddy maxi panel vans are in different places slightly.
We realised this when we converted ours and bought the factory rear Kombi floor covering.
When you look at pics of them both, then you see the subtle differences.
Tom-8-0
Post by Tom-8-0 » Fri Mar 20, 2020 5:51 pm
Got it to fit with a little trimming. Perhaps took a little more off than I needed to but at least it fits nowImage. Image
Thanks again for your replies and advice. Very much appreciated Image
Jamk
Post by Jamk » Fri Mar 20, 2020 6:55 pm
Beautiful, get the welder out be careful of the welds getting through to the fuel tank ( you don’t need to drop it just get something up there to protect it)
Tom-8-0
Post by Tom-8-0 » Fri Mar 20, 2020 8:10 pm
Welder’s there at the ready mate. Just need to clean it up a bit more and remove paint to bare metal where welding. Planning on dropping the tank just a touch and putting some fire blanket over it Did you weld in your secondary panel as well @Jamk? Or did you bolt it? Have seen both options being done and just wondered the difference if any. Cheers, Tom
Jamk
Post by Jamk » Fri Mar 20, 2020 10:34 pm
I dropped the tank slightly to get something in to protect tank as well, the welder was out so I welded both panels in so it’s nice and secure, quite a few spot welds to do but I figured that’s how it was done in the touran from factory.
