My DAB signal is a bit pants, swapping my mirrors over to caddy life's in a week or so, been told you can squeeze the standard mirror antennas inside the smaller lifes. So now's the time to make a change if it makes any difference, Would a roof antenna make my signal any better or would they be more or less the same?
DAB reception
Re: DAB reception
I've got a roof aerial , it's really very good..... I think it's the way forward
Re: DAB reception
Fellas who live in areas where the reception is ropey reckon a powered antenna is better. I remember reading a post where Doc said if you colour code it, don’t use a metallic paint as it can cause signal issues.
- gazza31112
Re: DAB reception
Cheers lads I'll look into it
