Removal of Front bumper lower splitter?
Azz03
Post by Azz03 » Sat Mar 21, 2020 1:21 pm
Alright guys wondering if anyone could help I want to remove the lower bumper skirt there’s no visible screws in it so I’d imagine it’s bonded on with adhesive as the owner before me had done it.
Question is what’s the best way to remove this without damaging both the bumper and the skirt any help is greatly appreciated Image
Dav02
Re: Removal of Front bumper lower splitter?
Post by Dav02 » Sat Mar 21, 2020 3:45 pm
Heat & fishing wire or plastic trim removing tool. Try those. That's how I removed the rear badge (fishing wire) and side strips (trim remover).
Once you have it off use a caramel wheel to get rid of all the left over adhesive.
2016 Caddy Highline. 2.0 TDi 102ps (ReMapped to 180)
Build Thread
DeanWhit
Post by DeanWhit » Sat Mar 21, 2020 7:33 pm
Or tooth floss
Barbel330
Post by Barbel330 » Sat Mar 21, 2020 7:57 pm
If it’s bonded on you’re going to struggle
Instagram: @y_5cuf
Azz03
Post by Azz03 » Mon Mar 23, 2020 9:46 pm
Cheers guys I’ll give it a go worse case I’ll just cut it off as I won’t need it anymore due to a new one.
