Caddy 4 Wind noise
Grantek
Caddy 4 Wind noise
Post by Grantek » Sat Mar 21, 2020 4:52 pm
Hi all, anyone experienced wind noise in caddy 4 from what sounds like it’s at the windscreen? Not usual wind noise at high speed. Sounds more like tyre noise from an under inflated tyre. Happens at lower speeds and sounds like it’s at top of windscreen but hard to tell. I’ve checked all tyre pressures and no gaps around windscreen.
I have caddy life mirrors so don’t think it’s them. Also have wind deflectors fitted but I don’t think it’s them either. Weird one but hoping someone else has come across it. TIA
Caddy2020
Re: Caddy 4 Wind noise
Post by Caddy2020 » Sat Mar 21, 2020 5:32 pm
It's coming from driver side wing mirror mate on most caddys
Sent from my VOG-L09 using Tapatalk
Grantek
Post by Grantek » Sat Mar 21, 2020 6:57 pm
I have caddy life mirrors. They’re not affected with that issue
Grantek
Post by Grantek » Sun Mar 22, 2020 2:24 pm
Anyone have any idea?
Seaview
Post by Seaview » Sun Mar 22, 2020 11:21 pm
Has your van ever had the windscreen replaced?.
sbyrne2012
Post by sbyrne2012 » Sun Mar 22, 2020 11:22 pm
The left hand drive caddys have different type wing mirror to fix this problem
Seaview
Post by Seaview » Sun Mar 22, 2020 11:40 pm
He said top of windscreen . I've heard something similar turned out to be radio Ariel come loose which is located in top of screen.
Grantek
Post by Grantek » Mon Mar 23, 2020 12:50 pm
I believe it to be original windscreen as it’s still got vw marking. I’ll check out the aerial point if I can seen it. My mirrors are both the same size
Giddy
Post by Giddy » Mon Mar 23, 2020 12:55 pm
All antennas are inside the mirrors for Caddy 4, as far as I know.
Grantek
Post by Grantek » Mon Mar 23, 2020 6:34 pm
🤦‍♂️ Thanks giddy!
