Fuel tank removal
John M
Fuel tank removal
Post by John M » Tue Mar 24, 2020 4:26 pm
Hi guys, anyone done it ? is it simple/tricky and could it be done on my drive ?
Re: Fuel tank removal
Post by Doc » Tue Mar 24, 2020 5:00 pm
Definitely not a job for the driveway, it's quite difficult to get the neck out even when the van is up in the air on a lift.
You'll need to rear left wheel off, arch liner off, undo the screw at the filler then drop the tank by removing the two straps.
The fuel pipes and pump loom will flex enough to give you access to unclip them.
John M
Post by John M » Wed Mar 25, 2020 6:53 am
Cheers Doc, ill leave the rattle until this lockdowns done
AdoleFiddler
Post by AdoleFiddler » Sat Mar 28, 2020 6:29 pm
Bit of a hijack, sorry! Can you access the tank from inside the van at all? Is there a fuel sender anywhere?
John M
Post by John M » Sun Mar 29, 2020 9:21 am
No pal you cant, unless your handy with a grinder and want to cut away the floor above the sender unit.
AdoleFiddler
Post by AdoleFiddler » Mon Mar 30, 2020 4:34 pm
Where abouts would it be? Could be handy for access in the future
John M
Post by John M » Tue Mar 31, 2020 5:30 pm
approx 6 inches in from wheel arch on left side of the van...bit extreme tho mate.
