Help: rs big brakes
Re: Help: rs big brakes
Post by Doc » Sun May 10, 2020 11:50 pm
Are all these quotes absolutely necessary? This is getting out of hand.
rush roo
Post by rush roo » Sun May 10, 2020 11:53 pm
Thanks for letting me know
Jeffers76
Post by Jeffers76 » Mon May 11, 2020 12:09 am
I had 55mm hubs on my van to start with so was ok, I’ve just gone to the alloy version of the 55mm hub
rush roo
Post by rush roo » Mon May 11, 2020 12:11 am
Yeah will look in to what I can get and put on
james400
Post by james400 » Mon May 11, 2020 2:13 pm
I have the 8 pots on mine off the rs3 only just fit in my 18 tho Image
rush roo
Post by rush roo » Mon May 11, 2020 3:09 pm
What discs you running?
james400
Post by james400 » Mon May 11, 2020 3:18 pm
Rs3 but my whole front end is rs3 too
rush roo
Post by rush roo » Mon May 11, 2020 4:31 pm
Oh fair enough
DW2207
Post by DW2207 » Tue May 12, 2020 2:43 pm
My 8v rs3 as these brakes from build, why would you need to fit such powerful brakes on the caddy van, are you guys running over 350hp?
Interested why you would fit this braking set up.
james400
Post by james400 » Tue May 12, 2020 2:50 pm
In my case yes it will be and it 4wheel drive too but alot of it is looks I would say
Jeffers76
Post by Jeffers76 » Tue May 12, 2020 2:53 pm
It’s not necessarily about having 350bhp some of us just like to stop well, mine have saved me a few times when idiots have tried to pull out last min, if it saves my van from being smashed up am happy with it, an they were at a very good price compared to what am seeing the R32 set up go for, you don’t have to have a massive engine to have massive brakes and they look good
Barbel330
Post by Barbel330 » Tue May 12, 2020 3:01 pm
I’ve had numerous sets of brakes on my van since I owned it. Standard brakes are barely adequate when you carry lots of weight in the van. I upgraded to R32 calipers and discs and felt precisely zero improvement. Then I upgraded to R32 Tarox discs and pads and felt some slight improvement but still not the greatest brakes I’ve ever felt. Then I upgraded again to Brembo 18z 6 pots, these are a huge improvement and as mentioned above have saved my van a couple of times when if I’d had standard brakes I’d possibly have ended up crashing.
Instagram: @y_5cuf
rush roo
Post by rush roo » Tue May 12, 2020 7:49 pm
Couldn’t agree more aesthetics is a factor yeah but I carry a lot weight from time to time and the stopping power isn’t enough.
krzychur1
Post by krzychur1 » Sun May 17, 2020 11:19 am
I have 6 pot calipers from new audi s4 b9, and the brake rotors from new rsq3 375/36mmImage
rush roo
Post by rush roo » Fri May 22, 2020 6:29 pm
Must look mega I can’t see the pic though
