Viezu tuning box in ex-BG maxi
guybonn98
Post by guybonn98 » Tue May 12, 2020 6:13 pm
Wondering if anyone can help with this.. my ex-BG maxi has one of the viezu tuning boxes under the bonnet. Mine doesn’t seem to be plugged into anything and I wanted to try it just to see if it makes a difference, it has two parts coming from the box, one is cable tied down as if it doesn’t go onto anything but the other male part seems as if it’s the one that goes onto the fuel rail. However when I plug it in and take the OEM plug off, the fault in engine management light comes on flashing. Does anyone know anything about these things and how I can get it plugged in properly??
Cheers!
Re: Viezu tuning box in ex-BG maxi
Post by the swan fiend » Wed May 13, 2020 9:23 am
Hi mate. Quite a couple of lads have got ex gas vans and found these boxes. (Mine didn’t have one fitted) but the general thought was that they didn’t make a difference.
If I were you I’d not bother with it, if it’s a bit more oomph you want maybe a remap to 140 bop is worth considering?
guybonn98
Post by guybonn98 » Wed May 13, 2020 9:28 am
Okeydoke I think I’ll just leave it then! Perhaps that’s why it’s been disconnected.. cheers!
Post by the swan fiend » Wed May 13, 2020 9:33 am
Maybe so. I’ve not heard of one being connected and throwing a light on before.
veedubd
Post by veedubd » Thu May 14, 2020 9:52 am
Vehicle loom plugs into box then box into fuel rail, I believe there are 2 types of program for the Viezo box performance and economy, BG were fitted with the economy versions
Dcbautosvc
Post by Dcbautosvc » Sun May 17, 2020 9:28 am
Throw that box in the bin. Nothing but problems. I remove loads of them. Get it mapped properly if your after more power and economy.
RivalDealer2020
Post by RivalDealer2020 » Fri May 22, 2020 3:46 pm
Hi
I have a 65 plate ex British Gas caddy with one of the boxes in question installed
Mine works fine and I’ve left it in but did wonder what the benefits of having it where.
I contacted viezu and they told me it was fitted to the bg caddy’s to try and improve overall fleet fuel economy
If only a small percentage was saved per van the overall saving after it was multiplied by the 100’s of vans it they are fitted too would end up being a great saving.
I asked what the actual performance figures where with the box fitted but naturally they wouldn’t tell me.
What the guy did say however is that it apparently allows the max fuel rail pressure to be higher than standard but mainly gives all the extra power low down.
He recommended if I wanted more performance from my 1.6 caddy I should get a proper viezu remap.
He said it’s apparently perfectly fine to leave the box still in and get a remap too, personally when I do eventually get a map I’ll remove mine.
So any bg van which has a viezu box fitted should in theory produce more power than another standard 1.6 without
robblowen
Post by robblowen » Fri May 22, 2020 6:43 pm
I disappeared mine as soon as I found it mate, tuning boxes work by essentially lieing to the ECU. So any figures promised or even shown on your dash are pretty worthless. Get rid and get it booked in for a proper remap somewhere reputable dude!
