seat belt colour change?
archie191103
Post by archie191103 » Fri May 22, 2020 5:36 pm
anyone changed their seatbelts , if so how easy is it cheers ?
dan@biali
Post by dan@biali » Sat May 23, 2020 7:34 am
I did mine towards the beginning of my build. Pretty straightforward. B pillar trims off and the lower sill cover popped up to reveal the bolt at the bottom, top bolt is under the plastic cap which you just lever open. You’ll need to disconnect the battery so they airbag system has dissipated any charge before removing.
The seatbelts you can then have changed by trimming companies or do what I did and take the belts to http://www.fdts-seatbelts.co.uk/Index.html who can do it while you wait.
