Fog Light Issues
BlackEdition2014
Fog Light Issues
Post by BlackEdition2014 » Mon Jun 01, 2020 9:41 pm
Hi guys,
I am new to the forum and am looking for some help.
I have 2014 Black Edition Caddy, and the front drivers side fog light will not turn off.
The switch is off and the key is out. The only way to keep it off is to remove the bulb.
Does anyone have an idea on what could be causing the issue?
Thank you
BlackEdition2014
Re: Fog Light Issues
Post by BlackEdition2014 » Sat Jun 27, 2020 9:56 pm
Anyone have any ideas?
Seems an intermittent fault, but came home to a flat battery today because of it.
Thank you
Post by Doc » Sat Jun 27, 2020 10:20 pm
Are they factory fogs or have they been retrofitted?
When you remove the lamp, do you get a error warning?
I have genuine VCDS Hex V2 & VagCAN Pro for any of your programming needs.
BlackEdition2014
Post by BlackEdition2014 » Sat Jun 27, 2020 11:15 pm
Hi yes they are factory fitted, and the warning light does appear
Post by Doc » Sat Jun 27, 2020 11:39 pm
Ok, there have been some instances where people have had weird things happen and disconnecting the battery for a few minutes has sort it out.
Have you or can you try that and report back?
