Came to change the cabin interior bulbs today to leds and noticed the middle festoon bulb isn’t coming on when using the switch or opening the doors, I’m guessing this isn’t normal? The smaller bulbs either side are both working - could it be a fuse issue?
Middle Interior Bulb
- Philby258
Re: Middle Interior Bulb
Have you tried turning the bulb around LED’s only work one way round
- Cadz09
Yea as above, I done mine a couple weeks ago and had to turn them around
Thanks for reply guys, yeh I tried that but tbh the halogen bulb wasn’t working before that. Does anyone know where the interior light fuses are on a 17 plate caddy? Or even the fuse box diagram as I can’t find it for a 2017 model year vehicle anywhere...
- Giddy
All the bulbs inside the light are connected to the same circuit. If one work, all should work. You better check whats happening inside the light, perhaps it's just a matter if poor contact, as lots of press-fit contacts in there.
By the way, decent LED bulbs are not polarity dependant.
Thanks @Giddy, just had a look at your insta - I love the interior on your van, superb style and finish mate.
- Giddy
Thanks mate
Having the same interior light issue…..all interior bulbs are good but not working. Dash bulb out warning lamp on, fuses ? Seem ok
Try disconnecting the battery in case the BCM is in a muddle, it's been known to happen.
