Cluster swap
RyanG94
Cluster swap
Post by RyanG94 » Thu Jun 11, 2020 6:25 pm
Good evening all
Hope you are all safe i have been looking at a new cluster for the dash as in the past i have had top of the range seat leon and a few audi’s and the new caddy as much as i love her the dash just aint cutting it. I just miss the digital speedo reading in the middle screen. I dont really care about all the other bits they can do just the speedo reading. So if i get a newer golf or a polo cluster will it bolt straight in and plug in or will it all have to be rewired in?
Many thanks
Ryan
Re: Cluster swap
Post by Doc » Thu Jun 11, 2020 9:03 pm
Polo won't work, golf 6 will but you'll have to fit the circuit board into your case and the speed and RPM discs will look out of place as they are plain black.
You'll need a highline instrument cluster to get the digital speed display.
RyanG94
Re: Cluster swap
Post by RyanG94 » Fri Jun 12, 2020 11:00 am
Hi doc
Thank you for the help, just thinking is there a way to code the current cluster so it will read the mph in the center screen?
I have seen these obd eleven readers that you can change all the settings on a car?
Many thanks
Ryan
Re: Cluster swap
Post by Doc » Fri Jun 12, 2020 3:56 pm
What's the part number on your current cluster?
scatman75
Re: Cluster swap
Post by scatman75 » Tue Jul 28, 2020 10:54 pm
Hi doc
Many thanks
Ryan
you could buy a polarfis ,that will hook up to your existing cluster loom and display everything you need ,including speed...
