Fitting a Touran centre console
- Cabbs
Hey guys,
I’m about to fit a touran centre console with the ratchet armrest. Just wondering how you fix the rear half of it down to make it secure.
I’ve checked the how to section but didn’t see anything.
Thanks In advance.
Carl
Thanks In advance.
Carl
Re: Fitting a Touran centre console
I'm about to as well mate....tomorrow!
There are the two little sort of captive bolts, that slot into the side of the metal gearstick housing.....ill be getting some from TPS tomorrow, hopefully!
- Cabbs
[mention]Stedlocks [/mention]
I’ve bought every nut, bolt, screw there is for the console from vw Pat. So do the two slide bolts down the side line up Pat mate? I know the front is all the same but my lad said the sides don’t line up and the two screws in the cup holders go to nothing.
- Giddy
Do you have a complete centre console with inner air ducts or just outer skin?
- Cabbs
[mention]Giddy [/mention]
Just waiting on the front section to come but have everything else mate.
- Giddy
That's my inner parts fitted, it's Caddy 4, but how the centre console fits is no different to any other Caddy
Cup holder screws are screwed to the two speed nuts you can see in the middle.
- Cabbs
Ok cool. So take off the outer shell with Armrest and fit the inner section first? It just threw me as it came complete minus a broken vent, cupholder lid and surround which I’ve now replaced with new ones.
How does the inner section hold secure then at the back?
- Giddy
It's a solid square-ish piece, that gives all the structural strength and is bolted to a handbrake frame.
- Cabbs
Ok. Thanks for the advice.
We can help each other out fella!
I haven't started yet....i can't even work out how to split the shell from the cradle bit!
- Giddy
- Cabbs
That’s the diagram I ordered all my bits and bobs from. Haha.
Any ideas on the front section of air ducting mate?
I hear it’s a y shaped piece I need but it doesn’t show on Etka.
- Cabbs
Hahaha. We will master this consoleStedlocks wrote:We can help each other out fella!
Malarkey Pat.
- Giddy
@Cabbs There are 2 part numbers 1T0820723B and 1T0820723C, not sure what the difference between them, look the same
- Cabbs
Arrr right. I thought there was another section at the front that I needed from the Touran. So that the floor vents and console vent work too. I thought the vent might be different at the front as the caddy doesn’t normally have the console vent.
