Golf r32 mk5 pedals fitment ?
Crazy7ony
Post by Crazy7ony » Thu Jun 25, 2020 6:14 pm
These are from a 2004-2008 r32. Does anybody know if they will fit my 2014 maxi as plug and play or a complete no go ImageImageImage
Beaker2135
Re: Golf r32 mk5 pedals fitment ?
Post by Beaker2135 » Fri Jun 26, 2020 8:43 pm
They should fit fine, GTI ones do
I swapped the pedal to the Caddy throttle body as the floor fitting are different and the Caddy one fitted better IMHO
The hardest part is getting the throttle off the floor! There’s a How To on the forum
Crazy7ony
Post by Crazy7ony » Fri Jun 26, 2020 8:53 pm
@Beaker2135 ok you mean took the accelerator pedal apart and fitted the metal plate section ? But the unit as a whole is different ?
Beaker2135
Post by Beaker2135 » Fri Jun 26, 2020 10:13 pm
Yep I just the hinged part off and fitted it to mine. The caddy base is much deeper
I have a 2014 van and used MK5 GTI pedals
Cabbs
Post by Cabbs » Sat Jun 27, 2020 9:07 am
[mention]Crazy7ony [/mention]
Same here mate. Mines a 64 plate van to and I used the accelerator part as opposed to the full base as it’s different. It slides off to the side mate. Look for the clips underneath.
