Does any know if thier are footwell sensors in a mk4 caddy highline, also if not can thier ve a coding issue as thier is no power at compressor, replaced compressor and gassed up
Sent from my SM-N950F using Tapatalk
Air conditioning
- Sanny
Re: Air conditioning
Whether there are footwell sensors or not will depend on the climate control fitted. Not all Caddy4 will have them.
It is possible that coding will prevent the compressor making gas pressure, there should be fault codes for any active fault that might prevent this.
- Sanny
Its a factory system, i took it to some guys that deal with caddys they scanned it came up with sensors but when asked at tps for them they said they dont have footwell sensors
Any one around west london thats a wizz at caddy coding that can help with this thx
- Sanny
I have also changed the control panel to heated seats 1Sanny wrote:Its a factory system, i took it to some guys that deal with caddys they scanned it came up with sensors but when asked at tps for them they said they dont have footwell sensors
Sounds like you've fitted the wrong control panel or it's not coded correctly.
Do you have part numbers for your original panel and the one you fitted?
- Sanny
I am taking it to a guy tonight with the old panel and see what he can do ,goin for a new flappy paddle steering wheelDoc wrote:Sounds like you've fitted the wrong control panel or it's not coded correctly.
- Giddy
Did you do flap end stop adaptation and compressor 1st run in? If you have changed control panel, AC won't work without that.
http://wiki.ross-tech.com/wiki/index.ph ... )_Climatic
- Sanny
Got the new panel coded ,he checked the pressure sensor wires and 2 of them were cut fixed them now its working and he coded a few extra things
