ABS pump part number
RedLion
Post by RedLion » Sat Jul 11, 2020 4:23 pm
Hey folks,
wondering if one of the gurus around here can help, i have the abs and traction control lights on, after a bit of reading it seems the ABS pump is most likely at fault. I dont have access to VCDS and am on a bit of a budget, am i right in thinking that if i swap the alloy pump section and keep the existing module that it should be a fair fix and error free? if so can anyone furnish me with a part number?
Vehicle is a 2009 Maxi C20 1.9tdi
thanks in advance
Red
Re: ABS pump part number
Post by Doc » Sat Jul 11, 2020 4:43 pm
I suspect a wheel speed sensor or encoder sooner than a pump failure on your year of caddy.
Anyway, if you do want to go ahead a stick a pump on it, your electrical module will be a 1K0-907-379AF, get a pump with that module on and you should be fine.
You will need some form of diagnostic system if you get any air into the pump.
RedLion
Post by RedLion » Wed Jul 15, 2020 10:57 pm
Thanks Doc, the company i bought it from had previously been told the pump was faulty hence selling the vehicle, fingers crossed. The part arrived today . . .
RedLion
Post by RedLion » Wed Jul 22, 2020 9:26 am
So, yesterday I drove to meet @sean1066 for a little vcds diagnosis, and according to software the fault lies in the coding of the module rather than the part itself. Perhaps it has had something replaced in the past. Without having the original part am I knackered?
I didn’t know my caddy looked so rough until I saw Sean’s.
Post by Doc » Wed Jul 22, 2020 12:06 pm
What exactly was the fault code description?
RedLion
Post by RedLion » Wed Jul 22, 2020 1:45 pm
That’s a question for @sean1066 he has the file I believe
NZDubNurd
Post by NZDubNurd » Wed Jul 22, 2020 8:33 pm
VW can tell you what was originally fitted.
People think the letters on the end are supercession numbers and anything newer will work... it is NOT done like that on VW part numbers - the suffix letters regularly denote options and differences that may make parts completely incompatible.
Sean1066
Post by Sean1066 » Wed Jul 22, 2020 11:36 pm
@doc
I will post the scan tomorrow after work as I’ve not had a chance today.
My build thread
Sean1066
Post by Sean1066 » Thu Jul 23, 2020 6:46 pm
@doc
this is redlion scan
Tuesday,21,July,2020,14:05:54:30029
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WV1ZZZ2KZ8X122290 License Plate: AK09 BSX
Mileage: 200750km-124740mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 10 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZ8X122290 Mileage: 200750km-124740miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 PD HW: 03G 906 021 CG
Component: R4 1,9L EDC 000SG 2387
Revision: --H07--- Serial number: VWX7Z0H13NB1PF
Coding: 0000031
Shop #: WSC 35110 377 00160
VCID: 70B9D320F6A4475BA3B-8024
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0020801
Shop #: WSC 00000 000 00000
VCID: 76B5E53894C0696B797-8022
1 Fault Found:
01044 - Control Module Incorrectly Coded
003 - Mechanical Failure
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 01000008041093
Coding: 00884F030004100057000000000000000008FB075C000100000000000000
Shop #: WSC 35110 377 08192
VCID: 6FBBD05CEB9A58A3BA1-803A
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 050208 021 0501
Coding: 00038805
Shop #: WSC 35110
Address 10: Park/Steer Assist (J446) Labels:. 1K0-919-475.clb
Part No SW: 1K0 919 475 HW: 1K0 919 475
Component: PARKHILFE 005 1104
Revision: 00005000 Serial number: 0 263 004 193
Coding: 000001
VCID: 6FBBD05CE79A58A3BA1-803A
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD0HS0W0
Coding: 0012345
VCID: 7DA7FA14B1F63A3338D-8028
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BQ HW: 1K0 953 549 BQ
Component: J0527 051 0100
Coding: 0000001
VCID: 025D89E8C80845CB45F-8056
5 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 2K0 920 944 C HW: 2K0 920 944 C
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H13NB1PF
Coding: 0016401
Shop #: WSC 54064 210 66681
VCID: 2C0107501A0C63BBDF3-8078
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 270208F2001436
Coding: 89A01F020002027401
VCID: 303913203624075BE3B-8064
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1212
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 006 1206
Coding: 0000560
VCID: 38292B00DE54DF1BABB-806C
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 808B0C087F2D8405485A030010C0
VCID: 005983E0C60457DB53B-8054
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
2 Faults Found:
00930 - Locking Module for Central Locking; Rear Left (F222)
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000560
VCID: 392F2E04E55EC613545-806C
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 AD
Component: Radio GR0 034 0033
Revision: 0003404S Serial number: VWZ2Z2H6095659
Coding: 0020200
VCID: 6889BB40CE748F9BFBB-803C
End----------(Elapsed Time: 00:50, VBatt start/end: 12.1V/12.1V)-----------
My build thread
RedLion
Post by RedLion » Mon Jul 27, 2020 10:44 pm
Bump. Can anyone shed any light on this one?
Post by Doc » Tue Jul 28, 2020 5:53 am
Have you already changed the abs module?
RedLion
Post by RedLion » Tue Jul 28, 2020 7:59 am
Doc wrote:Have you already changed the abs module?
I have not, previous owner may have
Post by Doc » Tue Jul 28, 2020 9:21 am
Have a look at the ABS wiring.
The coding is correct for that module but if they've changed it from an older type it might need a wiring change.
If it is what i think, it's a simple wire swap on the module plug, the green link wire should be from position 15 to 22 for that module.
RedLion
Post by RedLion » Tue Jul 28, 2020 11:42 am
I’ve had a look at it doc, the green wire looks to be in position 6 not 15,
Took a picture of the connector
And of the pump that’s in there
Post by Doc » Tue Jul 28, 2020 12:59 pm
Maybe it's not green, have a look for the wire link looping two terminals together on the abs plug.
