ABS pump part number
RedLion
Re: ABS pump part number
Post by RedLion » Tue Jul 28, 2020 3:28 pm
I have located the offending article. It appears I am missing the appropriate tool for removing the pin. Bugger. The black/white is currently jumping from 22-25, the connector on the donor part sitting in the garage jumps 22-15. Do you have any links to a pin out diagram?
RedLion
Post by RedLion » Tue Jul 28, 2020 3:29 pm
And now the picture I forgot Image
Post by Doc » Tue Jul 28, 2020 4:29 pm
Ok, so it looks like they've replaced a 1K0-907-379P pump ABS unit, which are prone to failure, with a 1K0-907-379AF.
Because these are different generations,the wiring is slightly different.
The difference being that link wire which rather than link 22-25 are you have there, should link 15-22.
Move that and you'll need to go through the setup for the pump with VCDS.
I have genuine VCDS Hex V2 & VagCAN Pro for any of your programming needs.
RedLion
Post by RedLion » Tue Jul 28, 2020 6:09 pm
Thanks Doc, i have ordered the appropriate (I think) pin tools arriving tomorrow. So I’ll give it a bash, I’ll let you know if the van explodes :p in terms of vcds is it a complex job, I’m thinking of purchasing, but it means partitioning my Mac or buying a pc (yuck).
Post by Doc » Tue Jul 28, 2020 6:35 pm
It's not complex at all, it's all guided on the Ross-tech (VCDS makers) wiki.
Essentially, you login and do the adaptions one by one.
One of the adaptions just requires you to press the brake pedal hard after starting the adaption process.
NZDubNurd
Post by NZDubNurd » Wed Jul 29, 2020 8:51 am
and you have to remove the locking clip... THEN use the tool to get the terminals out.
RedLion
Post by RedLion » Wed Jul 29, 2020 9:45 am
As in the plastic cover for the connector that has the red lock and the cam to pull the connector away from the module?
RedLion
Post by RedLion » Wed Jul 29, 2020 12:28 pm
Or do you mean the purple secondary barrier?
Post by Doc » Wed Jul 29, 2020 2:18 pm
I'm sure he means the purple secondary barrier, you can't get to the wires without the back cover off.
Let us know how you get on with it.
RedLion
Post by RedLion » Wed Jul 29, 2020 5:59 pm
I figured as much, I’m going to attack it after the array of small humans that I own have finally stopped screaming and have gone to bed. Soon hopefully . . .
RedLion
Post by RedLion » Wed Jul 29, 2020 6:25 pm
Pin removal tool has in hand and I’m wondering whether to address this after I have purchased vcds, as you said I’ll need to set it up, am I best letting sleeping dogs lie for a minute?
Post by Doc » Wed Jul 29, 2020 6:27 pm
No difference, it's not working either way.
RedLion
Post by RedLion » Wed Jul 29, 2020 6:57 pm
Sir makes a valid point
