Help - window conversion coding
JStop
Post by JStop » Mon Jul 27, 2020 12:29 pm
Hi, I have fitted the parts from a touran straight to the caddy!
Window regulators and motors, looms and door cards.
Ran the 12v feed from fusebox.
I just need to code them now. Does anybody know the long code so I can get these babies working??
I'll be forever grateful!
danny6000xtr
Re: Help - window conversion coding
Post by danny6000xtr » Mon Jul 27, 2020 5:51 pm
Same i have just done the same. need help coding them in. i can operate the windows via vcds but nothing on the door panel switch?
Post by Doc » Tue Jul 28, 2020 5:09 am
If everything is matched correctly, as in from the same donor vehicle, there should be no need for coding.
JStop
Post by JStop » Wed Jul 29, 2020 5:24 pm
As my windows dont work! Does the convenience J519 module from the donor vehicle need to be replaced too?
Post by Doc » Wed Jul 29, 2020 5:30 pm
I've never had to replace the convenience module and don't believe I've ever heard of anyone having to.
JStop
Post by JStop » Wed Jul 29, 2020 5:36 pm
Thanks for your help! Might have had a dodgy seller for the bits then, as I have everything in place and still dknt work!
Might have to start again!
danny6000xtr
Post by danny6000xtr » Sun Aug 02, 2020 2:28 pm
i managed to get the windows working by repinning the t28 grey connector, for the windows there is a brown earth, and two feeds for the windows and illumination feed
danny6000xtr
Post by danny6000xtr » Sun Aug 02, 2020 4:58 pm
If you still a struggling i can help you rewire the plug. Let me know. I have elsawin to help with wiring diagrams.
JStop
Post by JStop » Mon Aug 03, 2020 7:57 am
Hey Danny, I'm confident the 12v feed is wired correctly and that my door harnesses are correct also! It's being taken for coding today so should be all good!
Thanks anyway
danny6000xtr
Post by danny6000xtr » Tue Aug 04, 2020 9:07 pm
how did it go does the windows now work?
JStop
Post by JStop » Tue Aug 04, 2020 9:19 pm
Not working yet! They've been coded, but I believe I have either the wrong motors or they're faulty!
I could do with reading values of the door modules to see if they're seeing the switch operation first, but I dont have diagnostic equipment that can perform live values!
JStop
Post by JStop » Tue Aug 04, 2020 9:24 pm
I have only just seen this.. the grey T28 connector in the A pillar? I fitted a 12v feed from the fusebox to the interior T28 connector, now I have my live and earth at the door module! Is there still something else that's needs to be done?
C Chis
Post by C Chis » Tue Aug 04, 2020 10:02 pm
What are the part numbers from the door modules?
My MTB Caddy Build Can be Found Here
danny6000xtr
Post by danny6000xtr » Tue Aug 04, 2020 10:05 pm
the connector i repinned was the connector from switches to motor, the way i found out is earthed few of the pins one by one and i found out the windows went down. i see if i can get a pin out for you
JStop
Post by JStop » Wed Aug 05, 2020 11:33 am
That would be great! Thanks
