2019 Mk4 caddy dash in 2005 Mk3 Caddy
scatman75
Post by scatman75 » Tue Jul 28, 2020 10:30 pm
so has anyone successfully done this mod at all,its something im looking into and any info on the subject is very much appreciated...
scatman75
Re: 2019 Mk4 caddy dash in 2005 Mk3 Caddy
Post by scatman75 » Wed Jul 29, 2020 5:20 pm
Just bumping this to see if anyone has any tips etc
Sent from my SM-N960F using Tapatalk
scatman75
Post by scatman75 » Wed Jul 29, 2020 5:23 pm
So picked up a mk4 dash,cluster and climate controlled yesterday ,bargain at $250 Au ...
Billyblunt
Post by Billyblunt » Wed Jul 29, 2020 5:28 pm
I tried to swap a highline cluster but the immo5 was having none of it. Make sure you seek out a good tec who is a wiz at that sort if thing.
scatman75
Post by scatman75 » Wed Jul 29, 2020 5:37 pm
Billyblunt wrote:I tried to swap a highline cluster but the immo3 was having none of it. Make sure you seek out a good tec who is a wiz at that sort if thing.
At present I've a 1T0 920 872 F and hopefully looking at getting these working ,hoping someone can tell if it's possible and what tools are needed to code them...Image
scatman75
Post by scatman75 » Wed Jul 29, 2020 8:36 pm
thanks billy ,ive done a few mk4 and mk5 golf clusters in my time,really just need to know what tools people are using...
scatman75
Post by scatman75 » Wed Jul 29, 2020 8:57 pm
can anyone confirm that this tool will program my new cluster into my caddy please...
ABRITES Cars Diagnostic-Tool AVDI
Post by Doc » Thu Jul 30, 2020 7:07 am
The instrument cluster you have there is the very latest Caddy4 type with component protection.
You'll need an official legitimate version of some instrument cluster tool for this.
VVDI, AVDI, are just two of the possibilities.
scatman75
Post by scatman75 » Thu Jul 30, 2020 9:02 am
hi doc ive now got a set of 5k0920860f and 5k0920861 both 2009 clocks,any idea if these are easier to code it mate..thanks
Post by Doc » Thu Jul 30, 2020 9:05 am
Probably not any easier, no.
In terms of labour, all are pretty much the same amount of work.
scatman75
Post by scatman75 » Thu Jul 30, 2020 10:13 am
ive got carprog here,i was able to read the 24c32 eeprom chip on a set of 5k0920870f clocks
i cant find a 24c32/64 chip on my 5k0920860f clocks,were is the info saved on these ones...
thanks
scatman75
Post by scatman75 » Thu Jul 30, 2020 11:41 am
Will this tool be able to program black and white display into a existing red display on my caddy and up to what year of cluster is possible..ImageImage
Post by Doc » Thu Jul 30, 2020 1:11 pm
From my experience, the EEPROM, whether it's 24C32 or 24C64, is in the same location just above and left of the speedometer stepper motor.
Post by Doc » Thu Jul 30, 2020 1:12 pm
I've not had any experience of that tool, don't know what it's capable of.
scatman75
Post by scatman75 » Thu Jul 30, 2020 7:17 pm
Here's a pic of the PCB ,there is no eeprom chip on that side at all,it's also not on the back side either ...ImageImage
