Modifying rear lights
Re: Modifying rear lights
Post by Stedlocks » Fri Jul 31, 2020 10:09 am
@caddyforcarp , I’m not sure, as the pin out is different, I think? Give em a ring, they are easy to talk to, and can probably answer.... the physical hole they fit in is the same though, as for as I’m aware?
Caddy4Carp
Post by Caddy4Carp » Fri Jul 31, 2020 10:47 am
Cheers stedlocks, Will speak them before I order anything.
“Any fool can make money, but show me someone who can make a moment”
anoneamus
Post by anoneamus » Fri Jul 31, 2020 10:58 am
Caddy4Carp wrote:
Thu Jul 30, 2020 4:27 pm
Was looking at these yesterday any idea if they would go on a 16 plate? Got quite bit of stuff I’d like on there but my wallets holding me back :lol:
Barndoor, yes, tailgate, no. You will need to repin the plug on the car side. Basically, you'd be doing a reverse of the Mk4 lights on Mk3 mod.
Caddy4Carp
Post by Caddy4Carp » Fri Jul 31, 2020 12:02 pm
I’m guessing this is fairly straight forward and just swapping pins or fitting an adapter?
anoneamus
Post by anoneamus » Fri Jul 31, 2020 12:46 pm
Once you get your post count up, and have access to the rest of the forum, you will find the info. It's swapping pins, I don't believe there is an adapter available.
