SOUTH AFRICAN MEMBERS THREAD
Russ74
Re: SOUTH AFRICAN MEMBERS THREAD
Post by Russ74 »
anoneamus wrote: Nice, sounds like an interesting mod. Set it somewhere in VCDS?
Have a read here
https://forums.ross-tech.com/index.php?threads/569/
dikkies101
Post by dikkies101 »
Hello, I have 2011 Caddy Maxi 2.0 TDI.. I'm from Port Elizabeth..!! Image
Sent from my ELS-NX9 using Tapatalk
anoneamus
Post by anoneamus »
Russ74 wrote: Mon Jan 11, 2021 8:50 pm Have a read here
Awesome, thanks! Check out the TPMS2 mod for ABS (Caddy Cross has compatible modules). It uses ABS to detect tire pressure variations. Super useful!
viewtopic.php?f=6&t=19523
Russ74
Post by Russ74 »
dikkies101 wrote:Hello, I have 2011 Caddy Maxi 2.0 TDI.. I'm from Port Elizabeth..!! Image
Hi Dikkies101
I’m also down in Port Elizabeth
Russ74
Post by Russ74 »
anoneamus wrote: Awesome, thanks! Check out the TPMS2 mod for ABS (Caddy Cross has compatible modules). It uses ABS to detect tire pressure variations. Super useful!
I’ll check it out
Thank you
Russ74
Post by Russ74 »
darthvader911 wrote:Hi all ,
Im from CT
My 2014 2.0Tdi is my work van,
Stage 1 Revo
Golf VR6 clutch and flywheel
Jom coilovers
17" rims
Android touch screen
Speaker upgrade + tweeters
To do :
Golf brake upgrade
Fit rear spoiler
Rear sway bar
Engine cover
When doing mk6 golf brakes do I need caliper carriers as well ?
Which engine cover do I use ?
Hi @darthvader911
Yes you will need the carriers and discs the caliper it’s self is the same.
Welcome to our SA chat
Russ74
Post by Russ74 »
Russ74 wrote: Have a read here
Hi @anoneamus
Have a look here
anoneamus
Post by anoneamus »
Russ74 wrote: Wed Jan 13, 2021 7:43 pm Have a look here
Thanks, can you feel any difference?
Russ74
Post by Russ74 »
anoneamus wrote: Thanks, can you feel any difference?
Haven’t pushed it as yet
Russ74
Post by Russ74 »
Rear Spoiler fitted
Also retrofitted PDC works well
dikkies101
Wow... That looks good
Servicon
Post by Servicon »
@Russ74 looks awesome. Is the PDC retrofitted to the radio showing the sensor graphics?
Russ74
Post by Russ74 »
No unfortunately it doesn’t show
Reason: Removed unnecessary quote of entire previous
anoneamus
Post by anoneamus »
@Russ74 Wow, you've been busy! You should have a look into the Combi/Transporter rear wiper mod on here.
Russ74
Post by Russ74 »
That’s my next mod lol
