SOUTH AFRICAN MEMBERS THREAD
Servicon
Re: SOUTH AFRICAN MEMBERS THREAD
Post by Servicon »
Hi @Russ74, I just seen that you have a silver diffuser on the rear bumper. Nice touch that I didn't notice before. How did you do that mod?
Russ74
Post by Russ74 »
Hi @Servicon
The Cross Caddy’s come standard like that.
enstuff
Post by enstuff »
Hi
Yeah, a South African Caddy Thread! I have a 2019 Caddy MK4 Crew Bus and would like help with following:
1) Have anyone added the rearview camera to the barn door?
2) The headlights are not the greatest, what is the best, non Xenon, bulb upgrade recommendations?
Thank you
Russ74
Post by Russ74 »
Hi I did the rear view camera to the barn door. Works very well must say.
enstuff
Post by enstuff »
@Russ74 Did you this yourself and what was the costs? Thanks
Russ74
Post by Russ74 »
Yes I did it myself pretty simple. I got my reverse camera off AliExpress.
anoneamus
Post by anoneamus »
Russ74 wrote: Mon May 17, 2021 7:32 pm Hi I did the rear view camera to the barn door. Works very well must say.
Wow, PDC and reverse camera! I just use towbar... :lol:
Russ74
Post by Russ74 »
funny enough with my wife’s R I had reverse camera and pcd and I still managed to hit a tree at Dassiesfontien the farm stall just before Caledon Cape Towns Side
Russ74
Post by Russ74 »
6 speed conversion done today. Man I must say it’s a well worth it mod.
I needed the 6 speed Box from a Jetta/Golf BKD.
BKD Starter.
The mounting that bolts on the box for the cables. The linkages. BKD dual mass flywheel and clutch.
Golf 5 side shafts.Left and Right.
Also the pipe for the slave cylinder.
Took about 6 hrs to fit start to finish providing you have all the parts.
KaddiShak
Post by KaddiShak »
Are the gear ratios closer together on the 6 speed giving you quicker acceleration through the gears or where you looking for that overdrive 6th gear ?
Russ74
Post by Russ74 »
The ratios are a bit closer but the 6th has dropped considerably about 300-500rpms
anoneamus
Post by anoneamus »
Wow, impressive. Did you use 2nd hand or new parts? I had a warranty replaced (5 speed) gearbox recently, and wanted the agent to swap it to 6 speed instead of replacing 5 speed. They were having none of it though. Extended warranty cost me R500/month, the replacement gearbox and clutch (replaced separately, both under warranty) were about R140K! :shock:
At some point I may try a (4x4) synchro upgrade. It's gonna be eye-wateringly expensive. Might try shipping 2nd hand parts from Europe if I can't find a way to do it from parts that are available 2nd hand here. I do a lot of "Cross" in the Cross, but so far the clearance has been more of an issue than lack of 4x4 (AT tyres do help).
enstuff
Post by enstuff »
What headlight upgrades (Halogen bulbs) will you recommend that are locally available?
I have seen two recommended:
Osram night breaker laser or Philips? Any others
Secondly, does the Caddy use H4 or H7 for normal headlights?
Russ74
Post by Russ74 »
Hi Your caddy should take H7s
Both of the brands Phillips or Osram is good.
Midas Autozone should stock them.
Russ74
Post by Russ74 »
@anoneamus"]
I managed to get a new KRM box. Gearbox code says it comes out in the 2.0tdi Sirocco.
