Side strips
BenRR
Side strips
Post by BenRR »
Does anyone know what the strips are called
down the side of the van that are black plastic, I want to get them colour matched white but ideally wanted a primed set and not have to spray the plastic ones. Can’t seem to find any online.
Barbel330
Re: Side strips
Post by Barbel330 »
Mouldings. Look for used Touran mouldings as they’re painted and relatively cheap.
Instagram: @y_5cuf
BenRR
Re: Side strips
Post by BenRR »
Thanks mate I’ll take a look
Barbel330
Re: Side strips
Post by Barbel330 »
Instagram: @y_5cuf
BenRR
Re: Side strips
Post by BenRR »
Ideal bud thanks 👍
Papa Bear
Re: Side strips
Post by Papa Bear »
Are Touran ones only for swb?
Black
Marmite lover!!!
VCDS
BenRR
Re: Side strips
Post by BenRR »
I’ve got hold of some mouldings now, do you know if I’d need clips to stick them on when they’re painted? If so could you recommend some decent ones?
Barbel330
Re: Side strips
Post by Barbel330 »
They’re just stuck on with double sided tape
Instagram: @y_5cuf
BenRR
Re: Side strips
Post by BenRR »
Ah nice one mate cheers
Tcaddy
Re: Side strips
Post by Tcaddy »
That looks a good modification to break up the side of the van. Another one to add to the to do list!
bibbycaddy
Re: Side strips
Post by bibbycaddy »
Could you not just remove and spray your original black mouldings? That was my plan along with front and rear bumper...
Caddyluv
Re: Side strips
Post by Caddyluv »
You can but the hours it takes to flat sand off the texture sometimes it’s cheaper to buy pre painted ones.
bibbycaddy
Re: Side strips
Fair enough might have to see if local scrappy has anything in!
