Side strips
Side strips
Does anyone know what the strips are called
down the side of the van that are black plastic, I want to get them colour matched white but ideally wanted a primed set and not have to spray the plastic ones. Can’t seem to find any online.
- Barbel330
Re: Side strips
Mouldings. Look for used Touran mouldings as they’re painted and relatively cheap.
Instagram: @y_5cuf
Re: Side strips
Thanks mate I’ll take a look
- Barbel330
Re: Side strips
Ideal bud thanks
- Papa Bear
Re: Side strips
Are Touran ones only for swb?
Black
Marmite lover!!!
VCDS
Black
Marmite lover!!!
VCDS
Re: Side strips
I’ve got hold of some mouldings now, do you know if I’d need clips to stick them on when they’re painted? If so could you recommend some decent ones?
- Barbel330
Re: Side strips
Ah nice one mate cheers
Re: Side strips
That looks a good modification to break up the side of the van. Another one to add to the to do list!
Re: Side strips
Could you not just remove and spray your original black mouldings? That was my plan along with front and rear bumper...
- Caddyluv
Re: Side strips
You can but the hours it takes to flat sand off the texture sometimes it’s cheaper to buy pre painted ones.
Re: Side strips
Fair enough might have to see if local scrappy has anything in!
