Hi everyone I’ve bought meself a caddy and I’m wanting to put a set of Riviera RF2 on it , but all the websites say that the alloys won’t fit my vehicle when I’ve seen the alloys on caddy’s ? Help would be greatly appreciated!
Thanks Folks ..
##Riviera Alloys Need Help%%
- Giddy
Re: ##Riviera Alloys Need Help%%
It's impossible to tell without knowing the wheel spec
Right so what do I have to find out ?? I’m very new to this crack lol appreciate the reply tho!!
- Giddy
Wheel size, 18", 19", 20"?
Width, something like 8J, 8.5J, etc.
Offset (ET), ET42, ET45, etc.
Assuming you know the basics, that Caddy bolt pattern (PCD) 5x112, Centre bore 57.1 (will need spigot rings if bigger).
Hi mate, www.willtheyfit.com will give you more information.
As Giddy rightly said, width, offset, rim size, centre bore and PCD are the important factors when choosing new wheels. It’s worth having a read up on what’s what to help you make the right choice. I did and found it beneficial.
If you go on the Riviera website there is a data sheet with the RF2 spec. This may help
Gents! Thank yous
- DeanWhit
LK Performance in Leeds will sort you out with a set. Have a look on their website.
