Heater blower resistor
slacky
Post by slacky » Thu Sep 10, 2020 10:05 pm
Hey guys
Looking for abit of advice regarding the heater blower resistor. About a year ago my heater only worked on setting 4 so googled it and seen its a common problem with the heater resistor so ordered a new one and stuck it in. Although it worked it made some funny noises.
A year later its stopped working again so I ordered another one stuck it in and although its working again its making funny noises when on. Out of curiosity I took it down from above the footwell to feel how hot it was and it was very hot. Hot enough you can't touch it. Now its got me abit concerned if I keep using it with how hot it was it could cause some damage.
Is it ment to be getting this hot and whys the resistor making funny noises when the blowers are on?
Re: Heater blower resistor
Post by Doc » Fri Sep 11, 2020 4:58 am
The fan resistor pack will only overheat if there is insufficient air flow across it to keep it cool or the fan in drawing too high a current.
Make sure that you've got a clean pollen filter in the system.
If you remove the fan you can disassemble it enough to get oil onto the plain bearings top and bottom. I usually flood the bottom bearing in about 30ml of oil before reassembly,l. You'll see how the fan sits in a recess that can gather water if any is drawn into the system.
I have genuine VCDS Hex V2 & VagCAN Pro for any of your programming needs.
slacky
Post by slacky » Mon Sep 14, 2020 6:02 am
The resistor is just pushed up above the passenger footwell is this the correct place? Where is the blower located? Would you say because of the noises coming from the resistor when the fans on its using to much current ?
Post by Doc » Mon Sep 14, 2020 7:42 am
The resistor should be in the duct, it has a space to clip into so it's in the airflow.
The fan is right over on the passenger side, you can't miss it as its motor is protruding down quite a bit. Needs a twist to remove.
