Hi Guys,
First post so no idea if this is the wrong section but I don't have access to the specific wheels section of the forum.
Replacing the standard wheels on my 2015 BG Maxi, can I place 18 VW rims with load rated tires on? I'm getting confused with load ratings but assume it's just the tires that are specific?
Mate has a set of black golf R rims but I don't want to buy them if they won't pass an MOT.
Cheers!
Caddy Maxi Wheels
Re: Caddy Maxi Wheels
Hi, welcome to the forum.
Your wheels will only fail an MOT if they have a weight stamped/cast into them which is less than the maximum corner weight of your caddy.
Most original equipment wheels don't have those markings but it's definitely worth a look to make sure.
Hi Doc,
Cheers for the reply I'll have a check of the wheels see if there's anything stamped on them, cheap solution for the wheels.
