Stance + coilovers review?????
Scoobysrt
Re: Stance + coilovers review?????
Post by Scoobysrt »
Slight update for mine, good as a place as any until I finally get round to doing a build thread,
My banging was actually the shock on the drivers side, the top bolt had come out and it was banging against the chassis.
Put a new bolt in and the banging and bouncing has disappeared.
I also have an admission that it seems I do actually have another hole on the back so I can drop it a bit more with modifying the plates, I will do that tomorrow when I fit the new head unit.
I've also measured up and found the perfect air bags to make an air lift kit so I can get up farmer's lanes and over speed humps, the helper spring kits commercially sold are for standard suspension and unsuitable for a lowered van.
D_EDD
Post by D_EDD »
Does anyone know if the caddy 2k stance+ kits fit mk4 vans?
Only their website it doesn’t list the mk4 2015 onwards.
Alex mc
Post by Alex mc »
@ D_EDD I have these on my MK 4 mate and they are decent. I’m running 19’s and if I’m honest it’s reasonably comfortable.
Giddy
Post by Giddy »
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
D_EDD
Post by D_EDD »
Alex mc they look good, can’t find any bad reviews on them.
Thanks again Giddy!
Shame they’re out of stock!!
D_EDD
Post by D_EDD »
Found a set will be with me Monday
tomo88
Post by tomo88 »
I need to get some of these on order 😁
D_EDD
Post by D_EDD »
Edit: I now have what I need
D_EDD
Post by D_EDD »
It’s dirty and badly lit, but I was to excited not to get a picture!
I’ll take a better one once clean and not the middle of the night.
Very pleased though Image
D_EDD
Post by D_EDD »
Found an hour to point the jet washer at the van yesterday, so here it is at work on the stance + coilovers and bbs monza’s 17”.
I’m really please with how it looks.
Shizzle mcfarlin
Post by Shizzle mcfarlin »
Just fitted the stance coilovers only thing i think is the rear shocks are quite bouncy but the front seems ok.
Shizzle mcfarlin
Ive had them 5 months...for the money they have done the job
shayd
Post by shayd »
Was looking at the stance kit , but people are saying the ride is quite harsh ?
Matt_2k
Post by Matt_2k »
Hi all,
I’ve got a stance+ and have had it on some time but now want to go lower. I’ve ordered wobble blocks, centralising plates and I need to cut my bump stops down.
How will I know if I need adjustable/ shorter drop links? Even at current height sometimes I hear a noise from the front end when turning at low speed. Could this be due to tension on the drop links?
Can anyone recommend what I should change the drop links to?
3rdLeg
Post by 3rdLeg »
I’ve got a set of stance+ to go on, kinda bought them in haste as I was skint at the time and wanted to lose that arch fisting asap.
6 months later I still haven’t got round to fitting them, so in hindsight should saved up and got ST’s, but anyway...
I’m gonna be in the drop link predicament soon and from prior experience with a low MK5 Golf(presuming the geometry is similar), BMW E61 (300mm long) links work, so I’m gonna try them again.
Adjustable ones are garbage(maybe the expensive ones are better) and the cheap aftermarket shortened ones don’t last long.
I fitted some Starline E61 links from euros and they were spot-on on my Golf; they’re M10 instead of M12 but didn’t seem to affect anything once properly tight.
