Favourite VCDS 2K Codings/Adaptions
Semster
Post by Semster » Thu Oct 01, 2020 3:11 am
Hi Guys. Just wondering what are the top and recommendations for adaptions and Codings for the 2K caddy. I have my hex cable and have played with a couple of things. Couldn’t get coming home to work though. I might be missing a step.
Thanks all
So Far activated.
Needle Sweep/Cenlebration
Changed aircon from china to ROW
Enabled cornering lights with fogs
reduced current to DRL (LED was very bright and scattered)
DRL off on turn signal
Horn beep on lock/unlock (activated but doesn't beep lol)
coming Home lights. all activated but can't get it to function at all...
Seat belt warning off
Auto lock turned off
Washer fluid warning turned on
Handbrake On turns off DRL
anoneamus
Re: Favourite VCDS 2K Codings/Adaptions
Post by anoneamus » Thu Oct 01, 2020 10:30 am
Plenty of contenders, but the one that has brought the most tangible benefits is the tyre pressure sensing via ABS. Have a look on the forum for TPMS.
ACalamita
Post by ACalamita » Thu Oct 01, 2020 10:59 am
The coming home lights...
Turn headlights on with car running, turn ignition off and pull key out, flash the full beams, then open the door. As you open the door, the "coming home" lights will come on for the specified amount of time :)
Geraout
Post by Geraout » Thu Oct 01, 2020 8:06 pm
Agree with the TPMS - it has saved me twice now.
Intrigued as to what swapping aircon from China to RoW does?
Beaker2135
Post by Beaker2135 » Thu Oct 01, 2020 8:23 pm
Comfort Blinks
Digital Speedo
Sandur-Rx
Post by Sandur-Rx » Thu Oct 01, 2020 9:05 pm
Semester, what you mean with Changed aircon from china to ROW
Post by petrev » Thu Oct 01, 2020 9:31 pm
Comfort Blinks
Digital Speedo
Where is the code for Digital Speedo, if I may ask ?
Looked for it, but never come across it.
Semster
Post by Semster » Fri Oct 02, 2020 5:32 am
ACalamita wrote:The coming home lights...
Still can’t get this to work. I’ve tried every way. I haven’t had a good look at what’s available with options. I did a full adaptions report. But yet to look over if I missed a setting. I’ve only really had experience with mbq and coding and that was a while back. I’ll have to hope in my GTI 2017 and have a look at what settings I saved there as that car works no issue.
Semster
Post by Semster » Fri Oct 02, 2020 5:34 am
Sandur-Rx wrote:Semester, what you mean with Changed aircon from china to ROW
It’s in HVAC.
Not sure what difference it makes. But I’m not in China. I’m in Aus/ROW
my Car language was also set in German. Which I changed to English.
Semster
anoneamus wrote:Plenty of contenders, but the one that has brought the most tangible benefits is the tyre pressure sensing via ABS. Have a look on the forum for TPMS.
Sweet! I will take a look at that tonight.
Semster
Post by Semster » Fri Oct 02, 2020 5:36 am
I’m awaiting delivery of my Discover Media STD2. Be interesting to look through all those adaptions. Assuming I can get the car menu. As I have it flashed with latest MBQ menu layout.
Beaker2135
Post by Beaker2135 » Fri Oct 02, 2020 5:36 am
@petrev check this post in the How To.... for details
https://www.caddy2k.com/forum/viewtopi ... 22&t=23817
Prototypetom
Post by Prototypetom » Fri Oct 02, 2020 9:06 am
So looking at all this coding, and I’m new to it all what are people recommending to buy to get started.
Papa Bear
Post by Papa Bear » Fri Oct 02, 2020 11:11 am
Ross tech VCDS
If in the the uk, Gendan is the best bet
Don’t buy from eBay, it will most likely be a fake and can cause damage
Black
Marmite lover!!!
VCDS
Post by petrev » Fri Oct 02, 2020 11:44 am
Beaker2135 wrote:@petrev check this post in the How To.... for details
Ta.
