Favourite VCDS 2K Codings/Adaptions
Andrejm
Re: Favourite VCDS 2K Codings/Adaptions
Post by Andrejm » Wed Oct 07, 2020 10:25 pm
I got :
-cornering lights
-seat belt warning off
-DRL via separate lights
-hill hold assist off
-comfort turn signal to 5 times
Semster
Post by Semster » Fri Oct 09, 2020 9:31 pm
anyone know how to have rear lights on at the same time as dry. basically rears on constant ?
I got my pq composition media today. Very happy. Got it very cheap on eBay. It’s nice to have lots of adaptions to play with.
Unlocking cp and functions this week. Also having a go at enabling car status menu like mbq. And latest mib2.5 menu layout and themes. I’ll keep you posted.
R4Z4_9ts
Post by R4Z4_9ts » Sun Oct 11, 2020 7:46 pm
Just ordered vcds from Ross tech need to learn how to use it now lol
Semster
Post by Semster » Tue Oct 13, 2020 12:11 am
R4Z4_9ts wrote:Just ordered vcds from Ross tech need to learn how to use it now lol
Best tip. Write down notes for what you change. (Software does this in logs but it’s not as easy to follow)
First step: do a full auto scan. As well as a full adaption map.
if you have limited vin don’t connect to another car unless you want to spend a vin.
Papa Bear
Post by Papa Bear » Tue Oct 13, 2020 9:10 am
When done an auto scan, save it :D
Also you can connect to other cars to diagnose without using a vin license, if you make changes that requires a license to be used it does ask you if you are sure you want to
Black
Marmite lover!!!
VCDS
anoneamus
Post by anoneamus » Tue Oct 13, 2020 9:55 am
Turn the headlight switch to 1st position (marker lights).
R4Z4_9ts
Post by R4Z4_9ts » Wed Oct 14, 2020 6:29 pm
Semster wrote: Best tip. Write down notes for what you change. (Software does this in logs but it’s not as easy to follow)
Thanks Image I got the unlimited vin so should be alright there man Image
Beaker2135
Post by Beaker2135 » Sat Oct 17, 2020 8:15 am
Any body seen this or any other Easter Eggs?
I’ve stolen this from VCDS Users UK on Facebook but I made me smile
“Dont know if I'm the last person to notice this. But I discovered this little Easter Egg while code scanning an Audi today, I've never noticed this in about 8 years of using VCDS. Flux Capacitor module fitted Image properly confused me for a while. I later found out its to do with the time and date being set wrong on the laptop. So the car is ... From the future Image
Post by Doc » Sat Oct 17, 2020 9:32 am
I've never seen that before.
Gotta question why someone would not have the time and date set correctly on their laptop, that'd but the life out of me.
Beaker2135
Post by Beaker2135 » Sat Oct 17, 2020 9:37 am
Kind of makes me want to do it though to check it out :lol:
Dickyboy82
Post by Dickyboy82 » Sun Oct 18, 2020 1:48 am
Looking to order it myself. Which did you purchase?? And what cable did you buy
Post by FishermansFriend » Tue Oct 20, 2020 11:24 pm
Has anyone got a part number for the Flux Capacitor? :P
