Blue and red connectors ?
R4Z4_9ts
Post by R4Z4_9ts » Tue Oct 13, 2020 3:07 pm
Anyone know what these blue and red connectors are for behind the be caddy dash :/ also anyone know how I can wire up the hazzard light switch as I have no cables showing for it and no button see pics lol Image
Papa Bear
Re: Blue and red connectors ?
Post by Papa Bear » Tue Oct 13, 2020 5:05 pm
As you say you are missing the wiring for the hazard switch and those plugs are right below the hazard switch hole I would suggest they are the connectors for the hazard switch
Black
Marmite lover!!!
VCDS
Post by Doc » Tue Oct 13, 2020 5:07 pm
Looks as though someone has modified the factory wiring plug for the hazard switch to maybe fit some sort of interface.
Did your van have a beacon on at any point?
R4Z4_9ts
Post by R4Z4_9ts » Wed Oct 14, 2020 11:04 am
Papa Bear wrote:As you say you are missing the wiring for the hazard switch and those plugs are right below the hazard switch hole I would suggest they are the connectors for the hazard switch
Well that’s what I thought but those connectors do not fit into the hazzard switch as the switch has 4 big prongs and they have 6 small holes :/
R4Z4_9ts
Post by R4Z4_9ts » Wed Oct 14, 2020 11:06 am
Doc wrote:Looks as though someone has modified the factory wiring plug for the hazard switch to maybe fit some sort of interface.
Image that’s no good.. as in beacon do you mean a light or something on top? No never had a light
Post by Doc » Wed Oct 14, 2020 1:33 pm
Yea, as in a flashing light of some sort.
It's unusual to see modifications on the hazard switch wiring, I can't think of anything else it'd have had.
What was your caddy used for before you bought it?
R4Z4_9ts
Post by R4Z4_9ts » Wed Oct 14, 2020 1:34 pm
Doc wrote:Yea, as in a flashing light of some sort.
It’s a 2016 caddy but I think that dash inside is for a mk3 :/ so I probably have the wrong dash for the wiring areas
Post by Doc » Wed Oct 14, 2020 1:39 pm
Oh, ok.
You're right, that's not a Caddy4 dashboard.
The Caddy4 has a different hazard switch and also a passenger airbag warning light up there.
R4Z4_9ts
Post by R4Z4_9ts » Wed Oct 14, 2020 6:08 pm
Doc wrote:Oh, ok.
Yeah lol was a small nightmare, as the new no 4 hazard switch is square and has different connections and this dash has the triangle hole Image sorted now tho had to buy both hazard buttons and make one Image
