Poxy alarm help pls guys
Yetiman25
Post by Yetiman25 » Wed Oct 14, 2020 6:56 pm
So alarm just went off twice for no apparent reason. Can i tell from flashes on diode what it is ie door or ultrasonics? And does the alarm work on side doors via the push contacts?
First time i opened all doors and tailgate closed then rearmed went straight off. 2nd time did same again and bonnet as that was up earlier but it had been armed for ages.
Cheers in advance guys
Giddy
Re: Poxy alarm help pls guys
Post by Giddy » Wed Oct 14, 2020 7:44 pm
I had this once because of the slightly oxidised sliding door contacts. Easy to check, if you have some oxidation marks on them that probably be it. Just need to clean them.
The other common failure is the rear door bottom latch, if you have a barn door. It has built in switch and is prone to some moisture ingress.
Instagram: @giddywagen
Caddy 4, Highline, 1.4 TSI, Build thread https://www.caddy2k.com/forum/viewtopic ... 13&t=37368
Yetiman25
Post by Yetiman25 » Wed Oct 14, 2020 7:47 pm
Cheers giddy. Tailgate so hopefully one less poss issue. Just checked and contacts look clean as whistle. Only 2 1/2 years old anyway. Cleaned them just in case.
