Fan type washer jets
Grantek
Post by Grantek » Fri Oct 16, 2020 7:17 pm
Just fitted the fan type jets to my caddy 4 instead of the 3 individual spray type ones. I find the fan ones are hitting quite low on the windscreen.
Can anything be done with this?
Papa Bear
Re: Fan type washer jets
Post by Papa Bear » Fri Oct 16, 2020 7:30 pm
There is a screw accessible from the outside to adjust them
Black
Marmite lover!!!
VCDS
Katiecaddy
Post by Katiecaddy » Fri Oct 16, 2020 7:37 pm
Where abouts did you purchase the fan type? Are they OEM if so do you have the part numbers?
Papa Bear
Post by Papa Bear » Fri Oct 16, 2020 7:56 pm
I have the set from mine removed after I fitted the heated ones.
https://www.caddy2k.com/forum/viewtopic ... 20&t=44504
Black
Marmite lover!!!
VCDS
Caddyluv
Post by Caddyluv » Sat Oct 17, 2020 6:42 am
There are also heated fan jets which are good to.
Katiecaddy
Post by Katiecaddy » Sat Oct 17, 2020 8:08 am
Are the heated fan jets plug and play or do they require coding in?
Papa Bear
Post by Papa Bear » Sat Oct 17, 2020 8:35 am
Wired back to the fuse box, live when ignition on, no coding.
Black
Marmite lover!!!
VCDS
Katiecaddy
Post by Katiecaddy » Sat Oct 17, 2020 8:37 am
@papabear. Thanks for that. Wouldn’t mind the heated. We have those type on the Volvo and they work brilliant during the winter. :D
Caddyluv
Post by Caddyluv » Sun Oct 18, 2020 10:18 am
How to fit heated windscreen washers.
https://r.tapatalk.com/shareLink/topic? ... source=app
@katiecaddy
Katiecaddy
Post by Katiecaddy » Sun Oct 18, 2020 6:39 pm
@caddyluv thank you for the link, much appreciated :D
Caddyluv
Post by Caddyluv » Sun Oct 18, 2020 6:53 pm
No worries.
