Caddy 2017 engine cover,
helipil0t
Post by helipil0t » Fri Nov 13, 2020 9:20 pm
The one niggling aspect of my van was the filthy engine bay which basically stems from the lack of a engine cover as supplied from the factory, i was also told that the vans supplied with air con did not have the under guard fitted so as to keep the ac compressor cool. The result of this is a dirty engine bay probably not helped by previous owners.
After reading up on the topic here i found a suitable engine cover on e bay unusual in that it was marked up with a manufacturers badge ??? two ball end bolts were required for mounting to the front of the engine ( rear two fitted from the factory )
helipil0t
Re: Caddy 2017 engine cover,
Post by helipil0t » Fri Nov 13, 2020 9:27 pm
What with the dark nights coming in and of course lock down i ended up having plenty of spare time. So armed with rattle cans i had lying about in the workshop and a couple of badges purchased again from ebay i set about smartening up what was a dull black cover. Artistic licence applied and a few days later and much masking and swearing !! ending up with the finished result below.
helipil0t
Post by helipil0t » Fri Nov 13, 2020 9:32 pm
This weekend ( weather permitting ) will clean down the engine bay keeping away from the electrics and hopefully get some pics of it finished :D
Scoobysrt
Post by Scoobysrt » Fri Nov 13, 2020 9:35 pm
You've made a really nice job of that mate, im after one myself for my 2016 plate,
Im also going put a bonnet lining on as well if I can find one, my 07 plate has one and it makes it quieter, it will also be much nicer not seeing the primered underside.
helipil0t
Post by helipil0t » Fri Nov 13, 2020 9:42 pm
Hi Scoobysrt
Thanks for the comments, on the bonnet lining any idea what you are going to use for this ? i take it yours is a MK4 Caddy.
Scoobysrt
Post by Scoobysrt » Fri Nov 13, 2020 9:54 pm
Yes, its a 2016 highline. Im not sure to be honest, im going to see what replies you get in the bonnet insulation thread to be honest lol.
Otherwise ill take the one off my 07 plate and see if it fits the 2016 one and if it does ill order a mk3 one.
Marin97
Post by Marin97 » Sat Nov 14, 2020 1:25 pm
Hey! awsome!
I have 2017 caddy van and i hate that i dont have a engine cover, what car it fits from?
What kind of sprays did u use for that colours? What about heating?
Also where did u get this:
Thanks for a reply You can see my Caddy at this link in a album: https://ibb.co/album/8bB8TJ
:mrgreen: :mrgreen: Caddy VAN 2017 TDI DSG 6-speed 102hp :mrgreen: :mrgreen:
Pics:
tonyhill
Post by tonyhill » Sat Nov 14, 2020 4:01 pm
You've done a great job of spraying the cover. It should look amazing when fitted πŸ˜ŠπŸ‘
helipil0t
Post by helipil0t » Sun Nov 15, 2020 9:05 pm
Marin97 wrote: ↑
Hey! awsome!
Hi Had a look at you album your Caddy looks great, On the engine cover look for any same year VW AUDI SEAT car running the same engine and you will find most have covers as standard from the factory its only the vans that really dont have them fitted. I got a used cover and the two bolts off ebay ,
Paint just normal car touch up aerosol cans done this on a S3 engine in the past and had no problem heat related
helipil0t
Post by helipil0t » Sun Nov 15, 2020 9:08 pm
tonyhill wrote: ↑
Thanks Tony
Finally got it fitted today just a bit more cleaning of the bay and i will be happy ( between the rain storms !!!! ) just a bit more cleaning of the bay and i will be happy
helipil0t
Post by helipil0t » Sun Nov 15, 2020 9:16 pm
Cover fitted happy with the overall look
Kaddyken
Post by Kaddyken » Sun Nov 15, 2020 10:08 pm
To save anyone having to search, I found this info elsewhere on the forum - the cover part number is 03L103925R and the number for the o-ring for the oil filler neck is 03L133287
Scoobysrt
Post by Scoobysrt » Mon Nov 16, 2020 12:46 am
That looks great.
Marin97
Post by Marin97 » Mon Nov 16, 2020 1:29 pm
Kaddyken wrote: ↑
for 2k caddy yes but fpr 2017 i dont think so
2015 onwards
04L 103 925 Q (engine cover)
2x 04L 103 164 (ball joints)
1x 04L 133 287 (oil filler O ring)
Pics:
Kaddyken
Post by Kaddyken » Mon Nov 16, 2020 1:36 pm
Thanks for keeping me right Marin97 :D :D :D
