Audison speakers
Kingkong22
Audison speakers
Post by Kingkong22 » Sat Nov 14, 2020 6:52 am
Hi all
I’m thinking about fitting some Audison door speakers and tweeters on my Mk4 caddy, can anyone tell me if they are any good, I’m going to be using the factory fit head unit?
2016 white MK4 Caddy 102hp
Yetiman25
Re: Audison speakers
Post by Yetiman25 » Sat Nov 14, 2020 2:44 pm
Anything aftermarket will be better then factory crap. Audison are very good as are any speakers when your spending upwards of 150/200 quid. Problem is factory headunit will be so underpowered for a speaker like that unless they do a 35 rms ish speaker anything 75 rms upwards really needs a amp. Alpine do lower powered speakers g range or e range from memory they might be better suited.
Lister79
Post by Lister79 » Sat Nov 14, 2020 2:57 pm
I’ve fit some Audison APK’s in my doors/ dash and they sound absolutely brilliant (powered by RCD510). I previously had some Pioneer’s fit and the sound quality was easily noticeable after the change, so going from stock speakers the quality difference will be huge.
Kingkong22
Post by Kingkong22 » Sat Nov 14, 2020 4:02 pm
Ok thanks for the advice :D
I'm planning on replacing the speakers first, then later a head unit upgrade. I'll post some pictures once I have done :D
Philnanks
Post by Philnanks » Sun Nov 15, 2020 7:48 am
I’ve just upgraded the sound system in mine. Fitted Audison wideband and door speakers along with a processor and sub. That way I could keep the original head unit with incredible sound. Not cheap but you get what you pay for.
Iridium grey 2016 Caddy Maxi Life 150 DSG
bobededog
Post by bobededog » Sun Nov 15, 2020 12:07 pm
@philanks, which audison door speakers did you fit and you need to make / buy spacers.
Sent from my SM-N986B using Tapatalk
Philnanks
Post by Philnanks » Sun Nov 15, 2020 1:07 pm
Bobededog... the door speakers are Audison Prima 6.5 2ohms.
I had it all professionally installed and the chap made ply baffles to stop moisture getting into them. Spacers are not usually strong enough.
Awesome kit!
bobededog
Post by bobededog » Sun Nov 15, 2020 3:38 pm
Serious install there Phil.
He's definitely gone the extra mile.
Maybe I should rethink my diy ideas.
Philnanks
Post by Philnanks » Sun Nov 15, 2020 3:48 pm
Have a look at his Facebook site. He’s called Nick at Cornwall in-car audio visual. Very helpful even if you just wanted some advice. He knows his stuff! My Caddy install is on his FB page actually.
Kingkong22
Post by Kingkong22 » Fri Nov 20, 2020 7:20 pm
Awesome system Phil, did you use the factory head unit?
Philnanks
Post by Philnanks » Sat Nov 21, 2020 11:14 am
Yes mate. Wanted to keep the OEM look especially after just getting Apple CarPlay installed on it. The head unit on its own wouldn’t have been the best, the processor & sub has transformed the sound!
