Life mirrors - LHD or RHD
C Chis
Post by C Chis » Thu Nov 19, 2020 4:19 pm
Looking for a quick wee favour...
Can someone that has the caddy life mirrors fitted to their van check the distance between the window glass and the outer edge of the mirror surround on both sides for me.
My LHS (passenger side) is ~65mm, just wondering if it’s meant to be shorter for RHD van’s to give a better view along the side of the van?
Drivers side is ~55mm
My MTB Caddy Build Can be Found Here
Caddyluv
Re: Life mirrors - LHD or RHD
Post by Caddyluv » Thu Nov 19, 2020 4:57 pm
Yeah if you go and look at them from the front. Your see the one side is tucked in a bit for a better view when driving. Not many people notice. But now you have seen it your never miss it.
Gary.8
Post by Gary.8 » Thu Nov 19, 2020 5:16 pm
You've got LHD mirrors....
So the driver's side should be 65mm and not the passenger's side.
C Chis
Post by C Chis » Thu Nov 19, 2020 5:23 pm
Thanks guys!
I wondered if these were LHD ones, I’ll need to get a RHD one for the passenger side
Gary.8
Post by Gary.8 » Thu Nov 19, 2020 5:32 pm
I've got LHD mirrors and I'm the opposite... I'm fine with passenger's side but not the driver's side .
C Chis
Post by C Chis » Thu Nov 19, 2020 6:25 pm
Did you change the mirror glass over from aspherical (with the line down near the outer edge) to convex? A convex one will probably work for you.
Gary.8
Post by Gary.8 » Thu Nov 19, 2020 6:42 pm
No I've still got aspherical one for the driver side.. did think about getting one when you mentioned it on another thread so will give the convex one go cheers .
C Chis
Post by C Chis » Thu Nov 19, 2020 8:51 pm
Right, senior moment earlier.... correction below...
Your Drivers side mirror will be a convex one as your mirrors are like mine, left hand drive. I swapped my drivers side convex one for an aspherical one (with the line) to give a better rear view, so drivers side sorted.
I also swapped my passenger side one for a convex from aspherical which made it better but not quite right because of the gap above.
Gary.8
Post by Gary.8 » Thu Nov 19, 2020 9:45 pm
That's weird because I have a convex one in the passenger side as it took me a while to get use to it. I also brought a replacement aspherical mirror for the driver's side and fitted it straight away before I mounted the mirrors to the van....
So will have to dig the original mirror out and see if it's convex... that will save me buying one .
