Can someone point me in direction of coding mk4 rear lights to my 2014 caddy.
I put into VW specialist garage but for some reason had an issue coding them in
MK4 rear lights help
- Caddyluv
Re: MK4 rear lights help
I would question if they are Vw specialists. There is a conclusive how to in the “how to section”
- Andrejm
VCP coding in eeprom missing, maybe VW specialist work only with VCDS
Thanks for pointing out in this direction would love to see how VCP eeprom coding works since I have both VCDS. I m more interested in changing the glow from F > E
No they didn’t have VCP that’s why couldn’t be doneAndrejm wrote:VCP coding in eeprom missing, maybe VW specialist work only with VCDS
- Andrejm
Find someone with original VCP , and back on "how to" and you will find answer to that problem
